Mix sbc main bearing question
jsgarage
Re: Mix sbc main bearing question
Post by jsgarage » Mon Oct 02, 2017 10:04 pm
IMHO, Narrow bearings are not the same as small diameter bearings as far as friction reduction. At high rpms, smaller dia but wider bearings (SBC) work better (longer engine life) than slightly larger dia but narrower bearings (SBF) that are virtually the same surface area. Probably has something to do with the spread rate of oil being fed into the bearings but thats just a guess.
RCJ
Post by RCJ » Tue Oct 03, 2017 7:46 am
Bearing have more clearance at the parting line, when the oil groove extends in to that area there is more leakage. There are bearing with grooves that don't extend to the parting line.
engineguyBill
Post by engineguyBill » Tue Oct 03, 2017 9:47 am
Boot,
No, narrowed bearing will reduce friction in high RPM, maximum effort race engines. The narrow bearings will still form an effective oil wedge between the bearing shell and crank pin. As with anything else, bearing narrowing must be done conservatively - a bearing that is excessively narrowed will not be able to provide necessary support.
Bill
SAE Member (28+ years)
- Theodore Roosevelt
engineguyBill
Post by engineguyBill » Tue Oct 03, 2017 9:59 am
The area adjacent to the parting line has more clearance, due to the eccentric shape of the bearing shells. This area acts as a reservoir for oil to form the hydrodynamic wedge as the crankshaft rotates. The function of the groove in the upper bearing shell is to deliver oil to the eccentric (reservoir) area of the bearing.
Bill
Warp Speed
Post by Warp Speed » Tue Oct 03, 2017 10:06 am
The groove does not need to extend to the parting line/largest eccentric area to form this wedge you speak of....
DaveMcLain
Post by DaveMcLain » Tue Oct 03, 2017 11:17 am
How is it that a cam bearing which is fully round with no eccentricity built in manages to form a hydrodynamic wedge to separate the rotating cam journal from the block. Most of the time doing so with a simple oil hole.
engineguyBill
Post by engineguyBill » Wed Oct 04, 2017 9:13 am
Even though the camshaft is subject to the forces and pressure of followers, pushrods, rocker arms and valve springs, this pressure is much less than that encountered by rod and main bearings during the various cycles. The amount of oil delivered to the cam bearing journals is sufficient to keep this area lubricated.
Bill
RCJ
Post by RCJ » Wed Oct 04, 2017 12:35 pm
Check out callies Daido bearings.Havn't tried them , going to on the next motor.
