MODIFIED EDELBROCK 2958
swampbuggy
Post by swampbuggy » Mon Oct 09, 2017 9:42 pm
Wanted to share with everybody what the results are. Unfortunately i did NOT flow the manifold as cast on the CNC ported Brodix C head :( . Everybody seems to agree plenum work is VERY important for performance improvement so i went to work with the die-grinder. After enlarging the carb opening to 3.700" x 3.700" i made the radius's as great as i thought i could without cutting through the roof of the longer runners 1,7,2 and 8 and relieved the others some 3,5,4, and 6. The flow testing up to this point has been on the number 1 cylinder which i figured would be the more restrictive runner? This is an 18 degree head with Brodix's pprogram 254cc runner with a MCSA of 2,53 sq. in. net ( i did subtract for the rounded corners .750" radius). Flow testing was done on a bench which flows very close to a SF 1020 (cant remember the name of the flowbench) but it is a medium blue color. Intake on head with all other manifold runners taped off. .300"=210 .400"=264 .500"=302 .600"=325 .700"=325 I then made a 1" billet spacer and welded it to the intake AND welded on the outside of the plenum and on the top of the runners. Then started the grinding and radius work inside the plenum once again making the radius's a long as possible starting right at the gasket surface and working towards the runner roof downstream. I formed a piece of wire about an 1/8" diameter to conform to the entire radius of #1 runner, it fit to a 5" diam. metal can. which gives some idea of it's size. Results of flow test #2 .300"=208 .400"=267 .500"=315 .600"=343 .700"=350 . The number one intake port (head only) with radius at port mouth flowed as follows .300"=212 .400"=273 .500"=320 .600"=350 .700"=358 . Comments or questions welcome, Mark H.
swampbuggy
Re: MODIFIED EDELBROCK 2958
Post by swampbuggy » Mon Oct 09, 2017 9:47 pm
dad gummit i meant to put this in post pic.'s of what you are working on. I will try to move it to that thread, but i need coaching---anybody??????
user-17438
Post by user-17438 » Mon Oct 09, 2017 9:53 pm
Looks great!
mag2555
Post by mag2555 » Tue Oct 10, 2017 7:01 am
It looks good!
What's the expansion rate on average?
Plan on running atleast a 1050 Dominator my friend!
swampbuggy
Post by swampbuggy » Tue Oct 10, 2017 6:00 pm
MAG2255 i am planning on running a maxed out BLP 4150 like possibly their billet center, it flows appx. 1070, that should be plenty for 371 C.I. at appx. 8500 RPM. Not sure about your question, explain how to figure that and i will attempt. Mark
