1970 Torino Cobra 429 starter?
nickpohlaandp
Post by nickpohlaandp » Fri Oct 13, 2017 8:06 pm
So as luck would have it my buddy with the Torino is having starter heat soak issues with the new headers I just installed... of course it would, why wouldn't it? Now I want to put a high torque mini starter on it, but I have the option of 164 or 184 tooth flywheel. That's a 50/50 shot for me because I haven't got a clue. The car has a C6 in it. Anybody know which I should be getting? The car is about 15 miles away from me right now, otherwise I'd go out and spend a few minutes counting. Thanks for any help if you know.
aquartlow
Re: 1970 Torino Cobra 429 starter?
Post by aquartlow » Fri Oct 13, 2017 9:22 pm
Here is a pic of the size difference between a stock style mid 70's 460/C6 starter on left and a PMGR 460/E4OD starter from a '92-'97 Ford F250/F350(yes, it will directly fit a 460/C6), that little starter kicks the crap out of the larger starter and gives MUCH more clearance for headers. I use one on my '79 Ranchero with 472/C6 combo and would never want to go back to the 70's style of starter.
Good luck and hope this helps.
FWIW, the '92-'97 PMGR starter uses a 164 tooth flex plate.
nickpohlaandp
Post by nickpohlaandp » Fri Oct 13, 2017 10:16 pm
I know the size of the high torque starter is advantageous, that's why I want to use it. My question is about the tooth count on the flywheel
grandsport51
Post by grandsport51 » Sun Oct 15, 2017 9:32 am
Did you find the info
see link at ATP 184 tooth flywheel
http://atpautomotive.com/flexplate-z-242
LIGHT 'EM UP
nickpohlaandp
Post by nickpohlaandp » Sun Oct 15, 2017 12:09 pm
Ha! I found the info, but that's the first one that suggested 184. Welp, this should be fun. When the starter shows up I guess we'll know for sure then, right?
cab0154
Post by cab0154 » Sun Oct 15, 2017 1:00 pm
since a small block c6 uses a 164t flywheel I am going to go out on a limb and say the 429 will use the 184
nickpohlaandp
Post by nickpohlaandp » Sun Oct 15, 2017 1:17 pm
That's was my same train of thought, but I found a few things, and had a few people, say otherwise. I guess I'll know for sure when I go to install the starter. I'll post the findings when I get there.
cjperformance
Post by cjperformance » Tue Oct 17, 2017 8:19 pm
C6 passenger car big and small block are 164 tooth. Just different pcd on flex plate to crank bolts.
piston guy
Post by piston guy » Wed Oct 18, 2017 3:44 pm
+1 The 184 is an FE flex plate . 164 for the 460. I have the same starter as pictured on the right . It's in my '78 F350 race car hauler. ZERO heat soak with Hooker 6811 headers. Best deal out there.
Lem Evans
Post by Lem Evans » Wed Oct 18, 2017 8:23 pm
8)
B F Evans Ford Race Parts
270-278-2376
piston guy
Post by piston guy » Fri Oct 20, 2017 1:27 pm
I learned it all from you Lem!
Lem Evans
Post by Lem Evans » Fri Oct 20, 2017 5:49 pm
That's funny right there :-}
As you clearly know, It's a very easy deal on the 460 flexplate [not flywheel] they all are 164 regardless.....'78 Lincoln , JW wheel or Scat they are all the same tooth count. A flywheel is a different bird.
270-278-2376
cjperformance
Post by cjperformance » Fri Oct 20, 2017 6:29 pm
Exactly!
