GM IRON OVAL OPEN 14092359 CHAMBER CC???
topradman
Post by topradman » Mon Oct 16, 2017 9:39 pm
Can anyone supply a for sure chamber size on this head #14092359? Iron oval port, open chambered 427 tall deck 86-89 small valve 2.06/1.72 ( not a peanut port and nowhere can I find the cc's of the combustion chamber online after hours & hours of searching!
Thank you in advance for your help!!
tenxal
Re: GM IRON OVAL OPEN 14092359 CHAMBER CC???
Post by tenxal » Mon Oct 16, 2017 9:57 pm
116-118cc's according to my source(s). '88-'89-ish trucks, 2.19/1.72 valves, may or may not be marked 'High Perf'.
topradman
Post by topradman » Mon Oct 16, 2017 10:10 pm
My concern is that we are not talking about the same head. This definitely has 2.06 intake & 1.72 exhaust valves. It does have "High Perf" ( which we know is bs by the valve size ).. I figure the chamber is larger like the numbers you are listing but would be nice to be sure so I can pass this on to customer when we get the project finished.
I can't believe I didn't check this while the heads were off a few weeks back!! #-o
Thanks though.
mag2555
Post by mag2555 » Tue Oct 17, 2017 6:50 am
I found 118 CCs being listed right off the bat, but of course this is before a freshen up valve job if such was done?
topradman
Post by topradman » Tue Oct 17, 2017 9:19 am
Ok now..... that's why you have "5 wrenches" and I only have "2 wrenches"!! ( LOL ) Can I ask how you located that info or what your source was?
Thank you by the way!
If that is accurate, and assuming I have zero deck height that puts me at slightly under 8.5:1 CR.
Post by pdq67 » Tue Oct 17, 2017 12:20 pm
Does, "MORTEC", or, "Chevy Tech", have this info listed for BBC heads?
It's been a while since I have looked on their sites is all.....
topradman
Post by topradman » Tue Oct 17, 2017 12:24 pm
No they do not. They list the number but do not list the combustion chamber size. I cannot find this info anywhere on the web.
DCal
Post by DCal » Tue Oct 17, 2017 1:01 pm
After increasing the valves and a lite re-surfacing mine were 113 so 118cc stock seems reasonable.
topradman
Post by topradman » Tue Oct 17, 2017 3:50 pm
Thank you for the info!
