Manley valves
LaVelle
Manley valves
Post by LaVelle » Wed Oct 18, 2017 11:18 am
I have acquired a set of Manley valves and am trying to determine if they are an intake or exhaust material.
I have no idea what the original application is for them, (possibly Pontiac exhaust) they are 11/32 stems and 1.77-78" dia.
On the end of the stem it has ( MANLEY K-HB ).
Anyone know what the K-HB means.
mag2555
Re: Manley valves
Post by mag2555 » Wed Oct 18, 2017 12:12 pm
Sounds like a Pontiac Exh to me, and I can confirm that Manley Pontiac Exh valves do check in dead on at 1.77", where as Ferrea 's check in at 1.75".
Email Manley on the stamping code.
LaVelle
Re: Manley valves
Post by LaVelle » Wed Oct 18, 2017 3:06 pm
Manley said that the K-HB is a batch code.
Geoff2
Re: Manley valves
Post by Geoff2 » Thu Oct 19, 2017 5:07 am
Pontiac 1.77" exh valves came in 3 lengths, depending on the heads they were used in. 4.98", 5.1" & 5.2".
LaVelle
Re: Manley valves
Post by LaVelle » Thu Oct 19, 2017 5:50 pm
Looks like I have 8 of the 5.2's, Plan is to set up some peanut ports for 11/32 stems and will use them for the exhaust enlarging from the 1.72 and using small block chevy extended length 2.10's for the intakes.
mag2555
Re: Manley valves
Post by mag2555 » Fri Oct 20, 2017 6:41 am
That sounds good, and you can increase the valve bowl Throat size by .020" and still have good meat for a nice 3 angle seat job!
Be sure to back cut the valve's with a 30 to leave you a .075" wide seat.
travis
Re: Manley valves
Post by travis » Fri Oct 20, 2017 8:18 am
1.78" is also the stock intake valve on a lot of small block fords, but I don't remember what their length is
