Billet alumin(i)um torque plates sbc
kimosabi
Post by kimosabi » Mon Oct 23, 2017 4:45 am
Are anyone using them or are the steel BHJ types the ones to prefer. I'm thinking distortion.
Cubic_Cleveland
Re: Billet alumin(i)um torque plates sbc
Post by Cubic_Cleveland » Mon Oct 23, 2017 7:12 am
We use a few of them, mostly import engines, not SBC. Are you thinking bore distortion or torque plate distortion?
kimosabi
Post by kimosabi » Mon Oct 23, 2017 8:04 am
Torque plate distortion. Are they as rigid as a aluminum cylinder head? Well, most would probably say "duh" but there's so much stuff on the market now and obviously the goal would be that it simulates a cylinder head but the aluminum plates don't look as rigid as a cylinder head.
GOSFAST
Post by GOSFAST » Mon Oct 23, 2017 8:50 am
Been using aluminum plates for years now, found no issues between the cast pieces and the aluminums.
Thanks, Gary in N.Y.
P.S. To the best of my knowledge we MAY be the only shop in the country with a plate for the old Flathead Ford, measures 1.500" thick. Gets used regularly here! Actually serves a dual purpose (block/head/gasket pinning) on these builds! Have 4 ongoing builds as of today.
Jan. 2016 - New York Street Ride 7.56 @ 190 @ 3800#
(https://www.google.com/url?sa=t&rct=...12064104,d.cWw)
Cubic_Cleveland
Post by Cubic_Cleveland » Mon Oct 23, 2017 6:05 pm
Same here Gary, we can measure no difference in bore distortion between the aluminium torque plate and the head on the block when using the same hardware, and that’s all that matters.
As for the plate deforming, on our Nissan RB plate we’ve had for 10 years the bores are still round and still works the same as when we got it, you just have to use decent washers to stop biting into the aluminium...
engineguyBill
Post by engineguyBill » Mon Oct 23, 2017 6:29 pm
Aluminum works fine for torque plate. The important thing, as cubic_cleveland has pointed out, is the use of the same fasteners to attach the torque plate to the block as will be used to attach the heads to the block. Sturdy, thick-wall spacers will need to be fabricated in order to use these fasteners with the torque plate . . . . . . . .
Bill
SAE Member (28+ years)
- Theodore Roosevelt
stealth
Post by stealth » Wed Oct 25, 2017 8:19 pm
That’s pretty cool for the old flatty... do you notice much difference with and without? I heard the old ford flathead blocks were like bricks...way heavy and very ridged...
