Loss of oil pressure on braking
oldhead
Post by oldhead » Mon Oct 23, 2017 12:07 pm
I have a 8 1/4" Moroso pan, on hard braking the oil pressure drops. How much oil should I put in when changing the oil and filter. I have been using 6 Qts. :D :D :D :D Oldhead
Quicker then most
mag2555
Re: Loss of oil pressure on braking
Post by mag2555 » Mon Oct 23, 2017 12:20 pm
And what the heck engine are we talking about here?
What Moroso model pan?
I would work the other way and add in 2 more Qts then drop out 1/2 Qt at a time until the hard brake pressure drop shows back up.
turbo2256b
Post by turbo2256b » Mon Oct 23, 2017 12:22 pm
Might need a baffle to keep oil near the pickup. Had this happen on a pan I designed for the stroked 2.3 to 2.5 ranger engine. Worked fine until they installed it on the actual next years model with anti lock brakes were added.
statsystems
Post by statsystems » Mon Oct 23, 2017 1:01 pm
Most of those pans were 8 quarts plus the filter.
It would be nice to know what engine and part number of oil pan you are working with.
redliner
Post by redliner » Mon Oct 23, 2017 1:50 pm
If the windage tray is bolted to the pan as mine is, it should have the windage tray extend into the sump area above the oil pump. I have seen pics of some Moroso windage trays that did not do that.This keeps the oil in the sump during deceleration in my opinion....
pamotorman
Post by pamotorman » Mon Oct 23, 2017 2:02 pm
if the pan has swinging trap doors do not install the pan with the engine upside down as some trap doors can get stuck in the open position.
oldhead
Post by oldhead » Mon Oct 23, 2017 2:03 pm
I have used it for 20 years and just noticed the problem since installing Comp. Cams Elite roller lifters. It looks like Moroso #20180, 8 1/4 deep, it has a swing door. I also use the GM baffle :D :D :D :D Oldhead PS: Thinking back 20 years, it might have said 6 quarts, But is that plus 1 for the filter??
Quicker then most
Coloradoracer
Post by Coloradoracer » Mon Oct 23, 2017 3:29 pm
Normal condition for a wet sump oiling system. Most just don’t notice it. Only fix is an accumulator. Special pans, baffles, etc won’t work. Best fix is a dry sump but not needed on most builds.
Mark Goulette
Authorized Amsoil Retailer
pamotorman
Post by pamotorman » Mon Oct 23, 2017 3:44 pm
I check these pans by setting them level on the bench and 1 quart at a time I filled it with either water or kerosene till it reached to the bottom on the windage tray. added 1 quart for the filter and 1/2 quart for the oil passages in the engine.
ClassicComp
Post by ClassicComp » Mon Oct 23, 2017 5:35 pm
filter holds a quart and there's has to be a quart in transition.
That leaves 4 in the pan at most.
results speak for themselves
BobF
Straight8
Post by Straight8 » Mon Oct 23, 2017 7:54 pm
X2...the faster you go the faster you need to stop! Mine would do that every pass and recover soon as I turned to the return road.never had any issues because of it but dry sump cured that.
cjperformance
Post by cjperformance » Mon Oct 23, 2017 8:45 pm
If since installing the different lifters AND if you are still doing everything else the same it is probably more oil going past your new lifters than was with the old lifters. Therefore more oil on its way to the pan and less actually IN the pan. If this is the case, simply adding some extra oil will likely get your running pan level back to where it was prior to the new lifters.
Ideally though, oil pan/system rework would be a better solution OR as suggested just fit an accumulator to cover the times when this happens.
BlackoutSteve
Post by BlackoutSteve » Mon Oct 23, 2017 9:08 pm
What's the new lifter to bore clearance compared to the previous set?
Have you noticed a hot oil pressure change/drop?
Me thinking these are a tad smaller and you're pumping more oil around and leaving less in the pan.
Post pictures, or it didn't happen!
pamotorman
Post by pamotorman » Mon Oct 23, 2017 9:41 pm
when chevy came out with the BBC they switched to piddle valve lifters. at the drag strip you needed to run a quart over full to prevent a oil pressure drop because the piddle valve lifers allowed more oil to be trapped upstairs. we just changed the lifters to edge orifice type to stop the problem.
Keith Morganstein
Post by Keith Morganstein » Tue Oct 24, 2017 5:18 am
6 quarts in the pan itself. Add oil for the filter.
