Bearing clearances for high rpm sbc?
Walter R. Malik
Re: Bearing clearances for high rpm sbc?
Post by Walter R. Malik » Tue Oct 24, 2017 9:38 am
kimosabi wrote:
Mon Oct 23, 2017 11:42 pm
Walter R. Malik wrote:
Mon Oct 23, 2017 11:06 pm
In my opinion ... Large clearances are usually a band-aid for suspect parts or shoddy machine work, or both.
What would be large clearances to you?
More than .001" per inch of diameter; unless there is enough torque made to distort parts more than that.
Walter R. Malik
Post by Walter R. Malik » Tue Oct 24, 2017 9:49 am
rewguy wrote:
Mon Oct 23, 2017 11:24 pm
Darin Morgan stated awhile back......that he hadn't run less than .003 or .0035 on any clearance, rod or main, in any engine in many many years. I believe that is verbatim. And I have a good feeling he uses NO shoddy parts. And I also have a feeling that he has probably built, or been involved with building more horsepower than everyone on this thread combined. Just something to consider.
Just something to consider ...
Jon Kaase is a member here.
dwilliams
Post by dwilliams » Tue Oct 24, 2017 10:14 am
Callies has some graphs of bearing clearance vs. load capacity and oil flow. They show a "sweet spot" around .002."
Their graphs are in line with the SAE and IMechE papers I have.
statsystems
Re:
Post by statsystems » Tue Oct 24, 2017 10:34 am
Have a link to the graphs? I tried to find them and didn't see them.
Thanks
DaveMcLain
Post by DaveMcLain » Tue Oct 24, 2017 10:42 am
Those recommendations are ludicrous for a build like this guy is wanting to do. I'd recommend shooting for about .002 on the rod and .0025 on the mains, I think that's plenty with any reasonable oil.
BlitzA64
Post by BlitzA64 » Tue Oct 24, 2017 11:14 am
"A little too loose and you know, a little too tight and everyone knows" not sure if this was Confucius or not???!!! :D
nickpohlaandp
Post by nickpohlaandp » Tue Oct 24, 2017 12:36 pm
kimosabi wrote:
Tue Oct 24, 2017 6:33 am
vortecpro wrote:
Tue Oct 24, 2017 12:18 am
.0028/.0022 With a very strait crank.
How do you know the crank is straight when running?
Well you probably can't tell for 100% sure what's going on with the crank when it's running unless you have some badass telemetry sensors hooked up to pick up vibrations and interpret those vibrations into usable data, but generally when you're looking at straightness of the crank while it's running you check crank runout prior to installation (too much and get a different crank) and then go for good balancing. If your runout is good and your rotating assembly is properly balanced, your crank, theoretically, should be running straight.
Edit: The way I check runout (others may have different ways) is to install the #1 and #5 main bearing in the block, put the crank in, and put a dial indicator on the center main journal. Spin the crank over and see how much your needle moves. In a perfect world it wouldn't. realistically you'll see a little movement, maybe 0.001"
engineguyBill
Post by engineguyBill » Tue Oct 24, 2017 12:42 pm
[/quote]
If the crank checks-out straight prior to, or during, engine assembly it will remain relatively straight while running in a NA engine combination. Excessive crankshaft flex usually shows up in blown and/or turbocharged applications - especially when exotic fuels such as nitromethane are used. Some stroked crankshafts "may" exhibit some flex at high RPM is the main pin to rod pin overlap is significantly reduced - or nonexistent.
Bill
SAE Member (25+ years)
ASE Master Certified Engine Machinist
- Theodore Roosevelt
engineguyBill
Post by engineguyBill » Tue Oct 24, 2017 12:49 pm
[/quote]
[/quote]
That's the way I check for runout, too. - works for me. have also chucked the crank in the lathe and turned the crank by hand with dial indicator on the mains. The result is exactly the same as with the in-block method described in the previous post.
Bill
DaveMcLain
Post by DaveMcLain » Tue Oct 24, 2017 1:23 pm
[/quote]
[/quote]
Then what does the crank do when you press on it with your thumb?
Fireonthemountain
Post by Fireonthemountain » Tue Oct 24, 2017 1:32 pm
Things touch boom. Not good.
And what's the actual harm of bigger clearances?? Oil pressure at idle really matters little, as long as it jumps up with the rpms to good pressure numbers.
There are cranks that turn into "wet noodles" at higher rpms. Then you get into block flex and all the rest.
needforspeed66gt
Post by needforspeed66gt » Tue Oct 24, 2017 3:25 pm
This.
I rarely ever run over .001" per inch assuming good quality parts, and of course, precise machine work.
The cup engines run just under .001" per inch and they're spinning almost 10k rpm...if you use cheap parts that move too much under load, skip line honing the block, or you just take the rods out of the box and torque them up, that's when you'll spin a bearing and then blame the oil clearance rather than the machine work or assembler's attention to detail.
Nate
Engine Machinist
cjperformance
Post by cjperformance » Tue Oct 24, 2017 4:17 pm
[/quote]
[/quote]
Exactly ...
Post by MadBill » Tue Oct 24, 2017 7:00 pm
...And what's the actual harm of bigger clearances?? Oil pressure at idle really matters little, as long as it jumps up with the rpms to good pressure numbers...
The load capacity of the "hydrodynamic wedge' that supports the crank and rods drops rapidly as the clearance increases, so it's important to not run much more than enough to ensure distortion doesn't cause parts to 'ground out'. i.e., the ideal rod/main clearance in a 500 HP @ 7,000 RPM SBC might be 0.002"/0.0025", but the identical parts in a 1500 HP blown 8500 RPM application might need a thous or more greater.
On the other hand, the flow to maintain sufficient pressure will also increase with more clearance, thus increasing the oil's capacity for carrying off heat.. :-k
cjperformance
Post by cjperformance » Tue Oct 24, 2017 8:15 pm
. :-k
Dont start talking pressure Bill !, that will start a whole new debate! :shock: haha. But yes more clearance means more potential flow (if the pump is able)BUT typically with more clearance an according increase in oil viscosity choice would take place which theoretically will then increase the observed pressure , SO , for instance have we achieved more 'flow volume' going from say .002 with x oil and y pressure when compared to say .003 on the same bearing with x'thicker' oil to achieve the same y pressure ? Or have we simply achieved a resistance to flow that shows the same pressure reading BUT has a different flow volume? #-o i think ive just confused myself! So 2 ways to tackle opening up the clearance, ,,more flow volume same vis lube,, OR same flow volume increase vis of lube.
