Headbolt blueprints/cad files
CREngines
Post by CREngines » Tue Oct 24, 2017 4:20 pm
I am looking for some prints for head bolt hole locations so i can machine a flow bench fixture with some locating holes. looking for LS, Mopar sb/bb,ford SB, FE,460, and pontiac.
Can anybody help me out?
My email is CREngines@gmail.com
Thank you.
bigblockmopar
Re: Headbolt blueprints/cad files
Post by bigblockmopar » Tue Oct 24, 2017 4:44 pm
I've once found this image made by Doty Man. for a BigBlock Mopar which I saved for when I decided to make a torque plate.
Not sure of accuracy, as the torque plate plan never got done.
I did make a vector-trace in Adobe illustrator at the time from a steel headgasket but never confirmed it as been accurate.
CREngines
Post by CREngines » Tue Oct 24, 2017 5:52 pm
thank you sir.
Charliesauto
Post by Charliesauto » Tue Oct 24, 2017 10:07 pm
Ford SB is pretty easy, everything is symmetric. 4.380" x 4.240" with the cylinders centered in the bolt pattern.
Charliesauto
Post by Charliesauto » Tue Oct 24, 2017 11:32 pm
LS is similar to the SBF, all symmetric 4.400" x 4.331". Bores are centered in the head bolt pattern.
CREngines
Post by CREngines » Wed Oct 25, 2017 5:08 pm
thank you. really need 460 and pontiac if any one has them handy...
Charliesauto
Post by Charliesauto » Wed Oct 25, 2017 11:15 pm
I will have the 460 info in a couple of days. Can't help you with the Pontiac.
