NEW Pro-Filer SBC 23º Manifold
BOOT
Re: NEW Pro-Filer SBC 23º Manifold
Post by BOOT » Wed Oct 25, 2017 11:36 am
Yup those are the holes I was talking about.
Cris
Post by Cris » Wed Oct 25, 2017 1:40 pm
Any idea how the carb height compares to a 2925?
Thanks, Cris
user-9274568
Post by user-9274568 » Wed Oct 25, 2017 3:32 pm
resurrectionjoe wrote:
Wed Oct 25, 2017 11:34 am
* wrote:
Wed Oct 25, 2017 10:27 am
BOOT wrote:
Tue Oct 24, 2017 9:55 pm
Are those locating pin holes on the flange? If so not a fan of the location.
* I believe he's referring to these.
I knew that, just don't understand what the big deal is and why he's not a fan.
user-9274568
What's the big deal?
Kbails
Post by Kbails » Wed Oct 25, 2017 4:00 pm
I belive those holes are for the machine to mount to it.. kinda like some brodix heads 2 small holes in each end
Long Island, NY
cgarb
Post by cgarb » Wed Oct 25, 2017 4:13 pm
My concern with the holes would be a leak, because there isn't much material between the hole and the plenum, also the same from the hole to the outside. I'm sure if it is two flat surfaces with a gasket everything would be fine. If it bothered me that much I could just fill the holes with Devcon and file them flush...
ou812
Post by ou812 » Thu Oct 26, 2017 1:05 am
I like how they stretched the plenum front to back!
Brian Hafliger
IMM Engine & Dyno
http://www.immengines.com
http://www.neilhepburn.com
kimosabi
Post by kimosabi » Thu Oct 26, 2017 2:18 am
Looks like a great turbo manifold.
BOOT
Post by BOOT » Thu Oct 26, 2017 3:36 am
Bingo! If I got only one scratch on the entire intake it would be right there with my luck. Otherwise I'd prob try to tap n bolt a spacer on with some flush bolts.
Frankshaft
Post by Frankshaft » Thu Oct 26, 2017 8:40 am
Those holes are a NON issue, good god. They are kinda nice actually. You can dowel locate a spacer that you ported to match the plenum, and know it will line up perfect everytime. Its a common thing to do anyhow. I am assuming that's why they are there.
Walter R. Malik
Post by Walter R. Malik » Thu Oct 26, 2017 9:25 am
Lots of heads, intake manifolds and other stuff look really nice but, I have witnessed some awful ugly stuff actually make a bunch more power. ](*,)
I hope this nice looking piece will pass the comparative power tests ...
Although it is all really in the COMBINATION. :wink:
Newold1
Post by Newold1 » Thu Oct 26, 2017 9:52 am
Looks like a nice piece. I am pretty sure Wilson and Profiler did some good testing before the manifold was released for sale and use.
I like the fact they also included injector positions and fuel rail mounts for EFI. It's almost less expensive now to set up an efi based system on a manifold like this than it is to buy a really good big carb that's set up and dialed in for a particular application.
As for those holes I agree they can be helpful locating a spacer with some pins or if not needed just plug them with some short flush pins or RTV.
It's important for the enthusiasts and racers that these companies keep developing new and better product. Let's hope they were successful with their efforts!
user-9274568
Post by user-9274568 » Thu Oct 26, 2017 10:24 am
I have some ported manifolds that have .200-.300 left of carb flange.
Even their Snipers have them.
