Flow vs hp
andyf
Re: Flow vs hp
Post by andyf » Sun Oct 29, 2017 12:18 pm
Here is a 514 inch Mopar big block with Indy EZ heads. The EZ heads are the bottom of the list at Indy, basically a street head. They flow in the 350 to 360 range depending on what bench and what bore size you test them on. Engine makes right at 900 hp with EFI on a cast single 4bbl intake. Cam isn't huge, 282/288 duration. 2 inch dyno headers. So not exactly a Pro Stock engine. You can see the data on the dyno console, correction factor was 1.02 so this isn't one of the dyno tests where the correction factor is 20% or something like that.
https://www.youtube.com/watch?v=LZcFl7fy6FI
Andy F.
AR Engineering
Re: Flow vs hp
Post by MadBill » Sun Oct 29, 2017 12:38 pm
Wow Andy, most impressive! My 1970 nostalgia specs (except for a ~ 270/274° 0.746"/0.710" Jones roller) 12:1 2 x 4 bbl. 495" Can Am BBC heads flow~ 365/270 @ 0.750" and I've only been counting on ~ 750 HP/675 Tq. when I dyno it. Maybe I should raise the bar a bit... =D>
How much did the Q16 pick it up?
Newold1
Re: Flow vs hp
Post by Newold1 » Mon Oct 30, 2017 11:13 am
Those are very impressive results from a 514 wedge head Mopar.
1.75hp/cu.in. from those specs. Nicely done, Congratulations! =D>
swampbuggy
Re: Flow vs hp
Post by swampbuggy » Mon Oct 30, 2017 3:18 pm
Hey Andy would you tell us the Bore and stroke------max. CFM possible----intake valve size---and LSA---and con-rod length please ???? thanks Mark
user-29956
Re: Flow vs hp
Post by user-29956 » Mon Oct 30, 2017 3:41 pm
I also would be interested in some details. I am currently working with a major developer on a similar project. Good job!
Frankshaft
Re: Flow vs hp
Post by Frankshaft » Mon Oct 30, 2017 3:59 pm
So, he is supposed to give up all the details so you can give them to a major developer. Isn't that sort of an oxymoron? If they were a major developer, why would they need you? And why would he give you all the secrets, as I am sure none of this free. Why wouldn't he want to talk to the developer and profit for all his work.
user-29956
Re: Flow vs hp
Post by user-29956 » Mon Oct 30, 2017 4:08 pm
I have been subcontracted to analyze various facets of their initial airflow model. I am certainly not interested in stealing someone else's intellectual property. I apologize
andyf
Re: Flow vs hp
Post by andyf » Mon Oct 30, 2017 4:17 pm
Engine is 4.440 x 4.150. It has good parts in it, Mopar race block, Callies crank, Oliver 7.100 long rods and custom pistons from Diamond. Not a lot of tricks in the shortblock, lateral gas ports and 0.043 rings is about as trick as it gets.
Heads were CNC ported by Modern Cylinder Head and then touched up by Porter Racing Heads. Intake is ported by Wilson. Engine has Jesel rocker arms, 1.85 on the intake and 1.70 on the exhaust. Gross valve lift on the intake is 0.890 inches. Cam is Crane solid roller with their 0.481 lobes. Compression is a little over 15:1.
Andy F.
AR Engineering
andyf
Re: Flow vs hp
Post by andyf » Mon Oct 30, 2017 4:20 pm
Q16 was worth about 20 hp gain when I was running a 1250 Dominator. Q16 was worth zero with EFI. My guess is that injecting the Q16 on the back of the intake valve prevents it from absorbing heat in the intake so it kills off the power gain that we saw with a carb. But I'm open for suggestions.
I decided to stop using Q16 now that the engine is fuel injected since it is super expensive and doesn't make anymore power than the much cheaper X16. Besides, the Q16 smells horrible and gives me a head ache and it seems to chemically attack parts. So bye bye Q16 for me!
Andy F.
AR Engineering
andyf
Re: Flow vs hp
Post by andyf » Mon Oct 30, 2017 4:23 pm
I don't mind. This is an R&D engine and it is an open book. I freely share anything I learn with this engine. Here is an article from Hot Rod website on the engine: http://www.hotrod.com/articles/holley-hp-efi-install/
Andy F.
AR Engineering
