Short deck 615 big block chevy
evanjm
Post by evanjm » Fri Oct 27, 2017 8:19 pm
Hey all,
I'm looking for an off the shelf piston for a 615 short deck big block Chevy combination. Preferably something flat top and forged. Anyone know of anyone making something like this?
Thanks in advance,
Evan
Re: Short deck 615 big block chevy
Post by pdq67 » Sat Oct 28, 2017 12:34 am
Please tell us what your proposed B&S is to be?
I thought a 604.8" was about the largest we could make with a 9.8" tall deck BBC block? (4.625"b x 4.5" s here)...
And I really think the 598.3" is a tad more practical? (4.60" b x 4.5" s here)..
I know that I am partial to the 588" engine. (4.625" b x 4.375" s here)..
ProPower engines
Post by ProPower engines » Sat Oct 28, 2017 4:36 am
Hey all,
Thanks in advance,
Evan
If you are using a 4.750 stroke and a 6.385 rod mahle motor sports has a FT forged available in singles
I am using them in my shop truck in a std deck BBC 502 block
fdicrasto
Post by fdicrasto » Sat Oct 28, 2017 8:56 am
Shafiroff racing offers a 615" short deck that uses JE/SRP pistons. They might offer them for sale if not a proprietary deal.
DaveMcLain
Post by DaveMcLain » Sat Oct 28, 2017 9:24 am
Hey all,
Thanks in advance,
Evan
What's a 4.750 stroke 6.385 rod assembly like to balance?
GOSFAST
Post by GOSFAST » Sat Oct 28, 2017 10:19 am
I know these "big" short decks are common, but the reality is it's a really bad idea from the get go!
Choice of block used could make it even worse!
Recently gave feedback to Dave Calvert (C-P pistons) about what we were seeing on ALL the pistons coming out of a fairly high HP unit. Upon disassembly we had an issue with just about every previous brand of piston we used for this particular build, sent a couple to Dave and got some real good answers. They were literally trying to "screw" their way out the bottoms of the bores at BDC.
As a result of this entire occurrence C-P put a different cam grind on their next set we used, took the feedback again and ended up using this very grind on their "Bullet" line of pistons. To the best of my knowledge it's still the same today!
After the initial runs with their new pistons the ride went a whole lot faster with no other changes!
On a side note, this was ONLY a 4.250" stroke.
Thanks, Gary in N.Y.
P.S. I felt our issue was a combination of problems but the block ended up being the real culprit! Could never really thank Dave or the guys at C-P enough for their help.
Jan. 2016 - New York Street Ride 7.56 @ 190 @ 3800#
(https://www.google.com/url?sa=t&rct=...12064104,d.cWw)
Newold1
Post by Newold1 » Sat Oct 28, 2017 4:34 pm
What block is the OP using to get to his 615 and what will the ultimate bore size be? This makes a lot of difference if he should even go there with such a short piston.
Post by pdq67 » Sun Oct 29, 2017 7:44 am
Is it a, 4.60" b x 4.625" s engine?
FC-Pilot
Post by FC-Pilot » Thu Nov 02, 2017 3:36 pm
Any word back from this guy? I was kicking around the 604 idea as I have a 4.625 block sitting in the shop and a used 4.5 stroke crank and 6.385 rods on the shelf. With a set of iron merlin heads on top it would make for a sleeper.
Paul
"The latest tests prove exactly what my money tells them to prove".
