Nos on vortecs
stealth
Re: Nos on vortecs
Post by stealth » Sat Nov 04, 2017 6:13 pm
Interested too...would like to use 8 o2s...with rpm...
GARY C
Re: Nos on vortecs
Post by GARY C » Sat Nov 04, 2017 6:18 pm
Not quite as low dollar but here is a low dollar progressive box with basic data acquisition as well.
http://www.daytona-sensors.com/nc-1--nc ... llers.html
In-Tech
Re: Nos on vortecs
Post by In-Tech » Sat Nov 04, 2017 8:30 pm
That's not a bad little box Gary.
I have two of the old DI-194 4 channel serial port versions, old old from the 90's when they were $20 each. I just ordered an 8 channel DI-1100 USB.
Here are some things you can do as a DIY'er
DI-1100 4 channel
Analog
Channel 1 0-5v Wideband
Channel 2 RPM (might have to build a digital to analog device)
Channel 3 Fuel Pressure Sensor
Channel 4 Oil Pressure Sensor, or MAP Sensor or TPS or EGT using TC to voltage convertor
Hook directly to laptop for logging/monitoring or Rasberry PI with SD Card for Logging
DI-1100 8 Channel
Analog
Channel 2 0-5v Wideband
Channel 3 Throttle Position Sensor
Channel 4 Fuel Pressure Sensor
Channel 5 Oil Pressure Sensor
Channel 6 MAP Sensor
Channel 7 Exhaust Pressure Sensor
Channel 8 EGT w/TC to voltage convertor
Digital
Channel 4 RPM
Channel 5 0-15000hz MAF
Mini Dyno Portable Data acquisition system
DI-4108 8 Channel x 2 units daisychained with time stamped using ChannelStretch
Analog 0-5v
Channel 3 0-5v Wideband
Channel 4 0-5v Wideband
Channel 5 0-5v Wideband
Channel 6 0-5v Wideband
Channel 7 0-5v Wideband
Channel 8 0-5v Wideband
Channel 9 0-5v Wideband
Channel 10 0-5v Wideband
Channel 11 Throttle Position Sensor
Channel 12 Fuel Pressure Sensor
Channel 13 Oil Pressure Sensor
Channel 14 MAP Sensor
Channel 15 Coolant Temp Sensor using ohm to voltage convertor
Channel 16 Intake Air Temp Sensor using ohm to voltage convertor
Digital
Channel 4 RPM
DI-2008 8 Channel Thermocouple daisychained with above and time stamped using ChannelStretch
Analog 10mv-50mv Thermocouple
Channel 1 Thermocouple K-Type
Channel 2 Thermocouple K-Type
Channel 3 Thermocouple K-Type
Channel 4 Thermocouple K-Type
Channel 5 Thermocouple K-Type
Channel 6 Thermocouple K-Type
Channel 7 Thermocouple K-Type
Channel 8 Thermocouple K-Type
-Carl
In-Tech
Re: Nos on vortecs
Post by In-Tech » Sat Nov 04, 2017 9:45 pm
Code: Select all
DI-1100 8 Channel
Analog
Digital
Channel 4   RPM
-Carl
