Page 1 of 1
Need a pair of mopar "J" smallblock heads
Posted: Sat Nov 04, 2017 7:19 pm
by rewguy
I realize theyre pretty inexpensive. Ive found three pair for under 150$ ea pair. But I figured if i bought them from someone on here, I'd be more likely to get a set that wasnt cracked, etc. lol
Thanks.
Re: Need a pair of mopar "J" smallblock heads
Posted: Sat Nov 04, 2017 7:55 pm
by ProPower engines
Where are you located??
Posted: Sat Nov 04, 2017 8:05 pm
by PackardV8
Most we see are cracked, but I'll mag those which haven't been scrapped.
Posted: Sun Nov 05, 2017 12:05 am
by Diodedog
Probably close to 50 percent of the dozens I've done have cracks in the exhaust seats. Most of the time the cracks are very mild and never leak. If it's a stock rebuild or mild street and strip engine, they're usually fine. The big block 452 heads have the same problem, I believe the seats were cracked from the hardening process before they even left the factory.
Posted: Sun Nov 05, 2017 6:37 am
by mag2555
I have seen many a cracked 452 casting also , and yes they looked like from the factory!
I would still put seats in to get it all right unless you don't mind hydrolocking the motor some day and this always seems to happen above 5000 rpm and not at idle, and in doing such can take out a cylinder wall.
Posted: Sun Nov 05, 2017 1:33 pm
by PackardV8
Might as well ask, what is the application? By the time the OEM J-heads are put through cleaning and magging enough heads to find two good ones, milled, hard seats, 2.020" intakes, new guides, valves and springs, pay shipping, they're pushing the cost of aftermarket aluminum heads.
jack vines
Posted: Sun Nov 05, 2017 2:57 pm
by PackardV8
We checked and we've got a pair with no cracks - $200 for the cores, or will build to suit.
Posted: Mon Nov 06, 2017 1:24 am
by rewguy
The customer is determined to maintain a completely stock appearing cylinder head. They will be cut for 2.02 valves and have light bowl work done. They will end up on a 408 that should be around 415-425 hp. Hyd roller, 9.5-1 deal.
Posted: Mon Nov 06, 2017 1:26 am
by rewguy
PackardV8 wrote: ↑Sun Nov 05, 2017 2:57 pm
Well...... Can you get me a price on labor upfront so I can decide if it's in his budget? I will have valves here...... But.... Tell me what you think they need. Will be run on 92 oct pump fuel.
