Page 1 of 1
Antifriction Coating - Revisited
Posted: Thu Nov 09, 2017 12:09 pm
by CharlieB53
I may have missed this in a previous thread discussing these coatings.
I was thinking/wondering if any of these coating could be useful in reducing friction in typical gear type oil pumps. Would it even be worthwhile unless it was a max effort motor?
Lifters bores are another possibility however that could pose a problem shipping a block back and forth just for lifter bore coating. Bronze bushings installed by a local machine shop may be very cost effective.
Re: Antifriction Coating - Revisited
Posted: Sat Nov 11, 2017 7:57 am
by CharlieB53
120 views and no opinions as yet. I am surprised. Reducing the parasitic loss driving an oil pump has to take more than just a few HP.
The question is could this be a cost effective improvement? If so, which coating? As there are a number of companies offering these coatings.
I don't doubt the cup teams have already looked into this. What are they doing?
Posted: Sat Nov 11, 2017 8:08 am
by modok
Well, are we talking DLC coat one gear?
Not saying it IS a bad idea, but it would be very ironic to use a dry film lube in an oil pump.....it sure ain't dry in there. :lol:
I've thought a piston skirt coating in the housing would be good, make it too tight and let it make it's own clearance. Works for superchargers.....same thing I figure.
Posted: Sat Nov 11, 2017 8:38 am
by MadBill
On their website, Line2Line specifically mentions the benefits of building up oil pump clearances.
Posted: Sat Nov 11, 2017 8:58 am
by In-Tech
Yes Bill, I talked with them about this and am going to send in 10 used LS "gear sets" to do(makes it cost effective, I was quoted $20 each at that quantity). Of course brain 1 says YES, good experiment. Brain 2 says I will have time in disassembly/assembly(which happens anyway) and then it's only ~$100 for a new iron melling and I risk it not working and have to change pump in vehicle :?
Posted: Sat Nov 11, 2017 6:38 pm
by modok
"LS" oil pump
Meaning.... on the crank?
I'd leave it alone if so.
Posted: Sun Nov 12, 2017 3:21 am
by joe 90
I use oil as an anti friction coating on my engines.
Posted: Sun Nov 12, 2017 6:58 am
by Newold1
When talk is about engine parts coatings I think we should better define "anti-friction" versus "anti-wear" to better understand the differences between how various coatings and metal treatment systems work in an engine on various parts.
