Page 1 of 1
Adding Oil Pan Baffles and Trap Doors
Posted: Fri Nov 10, 2017 12:55 pm
by BBO Omega
Is there any "Pattern" acailable for adding Trap Doors and Baffles to a square bottomed Oil Pan? What is best used for a Trap Door. Most I have seen look like door hinges.
Re: Adding Oil Pan Baffles and Trap Doors
Posted: Fri Nov 10, 2017 3:04 pm
by ptuomov
BMW uses rubber flaps from the factory. They believe they are superior to metal doors. Same style also available in bulk from I think Tomei?
Posted: Fri Nov 10, 2017 4:34 pm
by RCJ
Speedway had a kit to add on to a sbc,it was around $25 .Had a trap door and a kickout.Worked good as long as you had the oil pan bolted to a block when welding.
Posted: Fri Nov 10, 2017 4:47 pm
by ProPower engines
Stainless piano hinge is what is used in most pans with the pin replaced with a smaller sized wire to allow if to move freely and stop before jamming open.
Posted: Fri Nov 10, 2017 5:02 pm
by ptuomov
This is what is in my car right now. I believe it works better with these (sump cover and walls with flaps) than without them. Front sump and pickup.
