Super stock hp level?
engineguyBill
Re: Super stock hp level?
Post by engineguyBill »
One thing about NHRA Super Stock classes is the fact that there are several variations of classes within Super Stock. For instance you have Super Stock Modified (i.e. SS/CM) which allows much more flexibility and is somewhat similar to the old Modified Production classes that were very popular back in the 70's.
Bill
SAE Member (30 years)
tenxal
Post by tenxal »
Truckedup wrote: Sat Dec 16, 2017 9:04 am Maybe...Let's take Jenkins first 1966 Chevy 2 327/350 in A/S......I believe he was running high to mid 11's back then? Figuring the car weight and traction that might be around 425-450HP?
That's probably in the ball park. It's important to note that the rules for Stock were actually more liberal than today. The cam used in Jenkins A/S 327-350 Nova was an Isky 550 on a 108 center line and the intake was an Edelbrock unit.
Modern day Stock Eliminator engines must use the factory intake and stock lift cam for the horse power claimed. For example, a 327-275 horse engine has a .390 int./.410 ex. cam and factory cast iron intake. A good one of these makes 425 to 440 hp. to be competitive.
1972ho
Post by 1972ho »
They also have the 4 and 6 cylinder classes with turbo or supercharger or normally aspirated some of the v-6’s are making over 650 hp and the turbos are over 1200 hp with only 200 cid but over 3400 lbs,or a normally aspirated 260 cid at 2100 lbs tube chassis cars.
Jagdpanzer
Post by Jagdpanzer »
What's amazing is Grump's A/S 327-350 Nova was running the dual-quad 426 hemi Mopars heads-up and beating them. Was even the A/S record holder for a while during that period.
Post by pdq67 »
Steve.k wrote: Tue Nov 14, 2017 1:07 pm Does anyone know roughly what hp level the small block super stock guys are sitting at? 355-360 cube range. Either auto or stick? Im not sure of all the different designations there is.
Imho, the old -041 head was not a, "double-hump", it had a rectangular pad with a triangle laying down on its longer 90 degree side.
Probably the same ports and chamber as a, "double-hump", so it really doesn't matter. It never had 2.02"/1.60" valves though.
bigjoe1
Show Guest
Show Guest
Post by bigjoe1 »
My 66 Nova 350 Hp only weighted 2640 when I first brought it home from the dealership--The Hemi probably was 34-3500 pounds
JOE SHERMAN RACING
Jagdpanzer
bigjoe1 wrote: Sat Dec 16, 2017 8:47 pm My 66 Nova 350 Hp only weighted 2640 when I first brought it home from the dealership--The Hemi probably was 34-3500 pounds
JOE SHERMAN RACING
Works out to about the same 8 lbs. per cubic inch
I can imagine the power and weight of the Nova was a better match for the limited tires they had to run back then.
Ron E
Post by Ron E »
Jagdpanzer wrote: Sat Dec 16, 2017 8:12 pm What's amazing is Grump's A/S 327-350 Nova was running the dual-quad 426 hemi Mopars heads-up and beating them. Was even the A/S record holder for a while during that period.
In the 7" tire days, Jenkins would put daylight between him and the heavier cars early in the run. However, to be accurate he didn't reach the finish line ahead of Jere Stahl at any national event.
Steve.k
Post by Steve.k »
The superstock hemi i know up here had quite a few national titles including at one time the mph record. The owner told me many years ago the engine dynoed over 880. I would imagine well north of that now.I started this thread as a guy i know was building stock eliminator cleveland car. Some very trick new ideas and he told me the hp would be quite a ways north of 600. Didn't know what to think of that as it takes( my experience at least) a good amount of work to hit 600 with good perf parts.
tenxal
Post by tenxal »
Steve.k wrote: Sun Dec 17, 2017 12:22 pmI started this thread as a guy i know was building stock eliminator cleveland car. Some very trick new ideas and he told me the hp would be quite a ways north of 600.
Did that car/engine ever get built?
Steve.k
Post by Steve.k »
Not yet. You heard rumblings or in same class.
1972ho
Post by 1972ho »
If it’s the guy Bill with the 71 Boss build he has sold are is selling off that 700 hp 351 cleveland stocker that was to run C&D/ stock.
Steve.k
Post by Steve.k »
Yes Bills motor. I did a set of heads mimicking the ones he did. We never did the angle milling but they made awesome flow at .600. The cool thing is no grinding once so ever.
vortecpro
Post by vortecpro »
Steve.k wrote: Sun Dec 17, 2017 7:00 pm Yes Bills motor. I did a set of heads mimicking the ones he did. We never did the angle milling but they made awesome flow at .600. The cool thing is no grinding once so ever.
My question is: At what weight does that car run at in C.
What is the factory boss 351 cleaveland cam lift?
How many cfm does the factory carb flow
1972ho
Post by 1972ho »
The Boss I think is nhra rated at 345 hp times 9.0 plus 170 for the driver.Thats why most racer run the HO at 325 in E or D more camshaft.And they even have a Cj cleveland that runs the same head as the Boss at 305 nhra rating with a little less cam than the Boss for E or F.
