"Belgian1979", if you ran it WOT "in MAP mode" it would correct for altitude and Barometer changes, if you do it right.
Is this a race car? Or street toy?
increased vacuum with increased ig timing
Re: increased vacuum with increased ig timing
Street.
I have a seperate sensor for baro which the ecu automatically uses for barometer changes (density). But like I tried to explain, there are some slight nuances for which you still have another add on correction curve. However I deem that unnecessary as the majority of difference from altitude stems from air density changes and the rest can be corrected by the EGO.
BTW : setting a 1200 rpm idle made a big difference in smooth running. To correct something that was said : I currently do not run 36° at idle. I run about 26-27°.
