2300 Ford
big moe
2300 Ford
Post by big moe » Thu Dec 14, 2017 4:13 pm
What is the smallest ID restricted anyone has run in the head on these ohc solid lifter engines ?
DJ58
Re: 2300 Ford
Post by DJ58 » Thu Dec 14, 2017 7:09 pm
none on solid lift cams for me, just the roller cams.
Dan
big moe
Re: 2300 Ford
Post by big moe » Thu Dec 14, 2017 7:33 pm
It’s a roller was wondering what size hole for restricting the oil to the top end .
DJ58
Re: 2300 Ford
Post by DJ58 » Thu Dec 14, 2017 8:06 pm
Give me the oil galley size and will check tomorrow. the OD of the restrictor will depend on the galley size there can be two different ones. I get mine from Esslinger.
most all of mine are for circle track :D
Dan
big moe
Re: 2300 Ford
Post by big moe » Thu Dec 14, 2017 8:15 pm
All in need is the in side dia I am making my own restictor would the inside be 060 080 125 250 ???? Circle track
DJ58
Re: 2300 Ford
Post by DJ58 » Thu Dec 14, 2017 8:37 pm
These just set inside of the back oil galley hole where you would put oil pressure guage line from head coming up from block.
Esslinger part number for 7/16 ID is E2348 and for 7/8 is E2350 hope this helps sorry but don't have the OD of the restrictors
at hand. it just floats in there.
Dan
big moe
Re: 2300 Ford
Post by big moe » Thu Dec 14, 2017 9:08 pm
Thanks but again all need to know is the inside diameter of the restrictor not the head .
mdurham47
Re: 2300 Ford
Post by mdurham47 » Fri Dec 15, 2017 8:21 am
The restrictor doesn't have a hole in it, it is solid and partially blocks the oil gallery.
MaxFlow
Re: 2300 Ford
Post by MaxFlow » Sun Dec 17, 2017 1:14 am
Are you planning on restricting the oil hole between the block and head surface? .080. The holes in the cam lobes are where the most oil comes. I've seen cams with 1/8 lobe oiling holes and they flood things quickly.
I'd watch when you do that because it bypasses the oil pump more and will strain the dizzy gear if running one and a 3/16 roll pin will be an absolute and it should be that size with a roller cam anyway.
Running big lift (>.720) and low duration(< 260) you can't restrict the oil before the cam lobe. It will wipe out the cam bearings quickly. Back when I use to run triple springs on those things it was a religious event to change the cam bearings regularly.
I don't know specifically your setup but if you post that up I'll try to assist.
Joe Stalnaker
WV
big moe
Re: 2300 Ford
Post by big moe » Sun Dec 17, 2017 5:55 pm
Yes l am looking to restrict that hole between the block and head the cam is roller someone has put a tube in the head but the hole is pretty big have not measured it yet I will and I will get the cam lift and the spring pressure on Monday and it is a dirt circle track 3/8 mile application and yes I was concerned about the cam bearings also . Thanks
jdlaramee
Re: 2300 Ford
Post by jdlaramee » Mon Dec 18, 2017 3:04 pm
Both the engines in my cars have .095... Its worked well for years..,JL
big moe
Re: 2300 Ford
Post by big moe » Mon Dec 18, 2017 7:31 pm
Cam is .630 lift .276 @ .050 my spring is 140 closed 420 open the head has a restictor in it with a .190 hole cam has .125 hole in the lobe is the restrictor hole to big or is it close Engine speed will be around 8000 rpm
MaxFlow
Re: 2300 Ford
Post by MaxFlow » Tue Dec 19, 2017 9:45 am
IMO .080 is enough but JD that posted above you said .095. He's built more than I have. That cam is rather mild. I see no worries for you with a .080-.095 restrictor. That big holed cam lobe can really flood things. A .190 restrictor would flood the hell out of everything IMO.
Joe Stalnaker
WV
n2xlr8n
Re: 2300 Ford
Post by n2xlr8n » Tue Dec 19, 2017 11:57 am
I'd take this^ to the bank.
You sell everything off, Joe?
big moe
Re: 2300 Ford
Post by big moe » Tue Dec 19, 2017 5:20 pm
Thanks for the input guys happy holidays !!!!!!
