Large port vortecs
ProPower engines
Re: Large port vortecs
Post by ProPower engines »
rocketracer380 wrote: Fri Jan 05, 2018 11:58 pm 11:1 slightly ported 225's vortecs with 2.05 1.6 valves heads flow 290 stock with 2.0 1.55 valves 630" solid roller 6" rods eagle crank super Vic intake 850 carb
Explain the term 225's vortecs you used.
Are you referring to a head with a 225 runner that has a vortec intake pattern???
The reason I ask is I don't believe you can get a 2.05 valve in a factory GM 906 vortec head. the 062 maybe as they did not use a hard seat installed at the factory making the bigger valve possible.
rocketracer380
Post by rocketracer380 »
No these are gm bow tie vortecs 225 runner they make 185 and 225 cc these are the later 19331472 is the part number they flow 290@ .600" stock
