351W lifter bushing blueprints
Does any have to share or know where I can purchase blueprints to install lifter bushings in a 351W block?
Re: 351W lifter bushing blueprints
Do you reference your front to rear locations from the datum hole in the pan rail or from the cylinder head dowels?
I have both.
Are you planning to do this on a manual mill?
I have both.
My friend is going to do it on his CNC mill.
He references off the bell housing. He said the head dowels would work
Thank you
Thank you
The lifter bores are 41.5 degrees from the cam/crank centerline.
If you use the datum hole in the pan rail near the rear cap on the drivers side here are the x-axis #'s
Passenger side
1.855"
3.585"
6.235"
7.965"
10.615"
12.345"
14.995"
16.725"
Driver side
1.115"
2.845"
5.495"
7.225"
9.875"
11.605"
14.255"
15.985"
If you use the right(passenger side) front cylinder head dowel:
Passenger side x-axis #'s
1.375"
3.105"
5.755"
7.485"
10.135"
11.865"
14.515"
16.245" "
Driver's side x-axis #'s from right front cylinder head dowel
2.115"
3.845"
6.495"
8.225"
10.875"
12.605"
15.255"
16.985"
If you want to check my info for typo's, you just need to know the lifters are 1.730" c-c and each cylinder is 4.380" c-c.
Passenger side
1.855"
3.585"
6.235"
7.965"
10.615"
12.345"
14.995"
16.725"
Driver side
1.115"
2.845"
5.495"
7.225"
9.875"
11.605"
14.255"
15.985"
1.375"
3.105"
5.755"
7.485"
10.135"
11.865"
14.515"
16.245" "
2.115"
3.845"
6.495"
8.225"
10.875"
12.605"
15.255"
16.985"
