VORTEC BOW-TIE HEADS
Has any body run any of the new Vortec Bow-tie heads
Website is up and running
Machine shop tour
Monthly Specials
Machine shop tour
Monthly Specials
Any dyno tests ??
Machine shop tour
Monthly Specials
Machine shop tour
Monthly Specials
Bowtie Vortec
Carl,
I am working on flow #'s now for both sets. The 25534351 small port has 185 cc intake and 65 cc exhaust. The 25534371 large port yields 215 cc intake and 84 cc exhaust. I will pass along the #'s when available.
Bob
Bob
The 203 headed motor was a fairly typical late model pavement type motor. Not a killer piece but moderate price, cam profile, etc..It was a flat top piston,flat tappet cam, super victor intake, 750 carb. It makes in the 570 hp area and seems to accelerate pretty good. I think if you did all the tricks, you could see in the 600 hp area with them.The smaller headed one we haven't got on the dyno yet.
Shawn
Shawn
Shawn did you stay with the 2.000 intake and the 1.55 exhaust valeve or go to the 2.020 and the 1.600 exhaust.shawn wrote:The 203 headed motor was a fairly typical late model pavement type motor. Not a killer piece but moderate price, cam profile, etc..It was a flat top piston,flat tappet cam, super victor intake, 750 carb. It makes in the 570 hp area and seems to accelerate pretty good. I think if you did all the tricks, you could see in the 600 hp area with them.The smaller headed one we haven't got on the dyno yet.
Shawn
And what was the compression ratio on the engine you tested.
And thanks for the info. Carl
Machine shop tour
Monthly Specials
Machine shop tour
Monthly Specials
I used the 1.55 exhaust valve with a 2.05 intake. It didn't seem to make much difference over the 2.02 ,but i wanted to try it.The compression was a little under 13.0-1.The chambers on the heads don't lend themselves to a dome without a custom piston, and i didn't want to cut or roll them over on bunch the first set i did, without knowing what they would do.I think that with a little more "undercover" work and roll them over some more and you could see quite a bit more power out of them.
Shawn
Shawn
Bowtie Vortec
Intake Small Vortec BT
.100" 67
.200" 136
.300" 182
.400" 223
.500" 251
.600" 240
.700" 240
Exhaust Small Vortec BT
.100" 53
.200" 100
.300" 128
.400" 145
.500" 152
.600" 164
.700" 166
Intake 175 cc
Exhaust 64 cc
Intake Large Vortec BT
.100" 63
.200" 133
.300" 182
.400" 228
.500" 258
.600" 255
.700" 261
Exhaust Large Vortec BT
.100" 50
.200" 100
.300" 134
.400" 154
.500" 168
.600" 168
.700" 169
Intake 206 cc
Exhaust 77 cc
2.00" Intake
1.55" Exhaust
.100" 67
.200" 136
.300" 182
.400" 223
.500" 251
.600" 240
.700" 240
.100" 53
.200" 100
.300" 128
.400" 145
.500" 152
.600" 164
.700" 166
Intake 175 cc
Exhaust 64 cc
.100" 63
.200" 133
.300" 182
.400" 228
.500" 258
.600" 255
.700" 261
.100" 50
.200" 100
.300" 134
.400" 154
.500" 168
.600" 168
.700" 169
Intake 206 cc
Exhaust 77 cc
2.00" Intake
1.55" Exhaust
I am curious if anyone has tried to unshroud the intake valve in the chamber on these heads? And if so, what were the improvements in flow??
I have had a set of these( 25534371, big port ) for a while, but am just now getting around to playing with them. The rules it will run under: cast iron, oem, unported, straight plug. In the last two years they have never pulled a head, they always seem to pull the intake manifold. This leaves me wondering what gains can be made in the combustion chamber.
I would be appreciative of any info, as I don't wish to sacrifice a head just to find out that there wasn't much gain to be had.
Thanks
Thanks
Carl,
http://chevyhiperformance.com/techartic ... 6_thunder/
Old Mag article on a circle track motor built with them.
Bret
Bret
We worked with PCCW Engines out of VT. on this engine in the pic as this was a little 13:01 big bore short stroke engine 358 and a 750 HP carb with all the bells and whistles as we took care of the block work on the Dart Little-M block and worked with them on the cylinder heads as this engine had a little more power and torque then the engine in the article and this engine was very impressive on the dyno 3 weeks ago.
If you need any more info call Randy at PCCW 802-457-3111
Machine shop tour
Monthly Specials
Machine shop tour
Monthly Specials
That engine is set up for valve spring oilers as the valve lift is around .700 just to keep the springs cool.hbps1978 wrote:Carl, may I ask what the purpose of the braided lines that are going into the valve covers on the engine in the pictures are for please? Oil circulation from the block?
Machine shop tour
Monthly Specials
Machine shop tour
Monthly Specials
- Wolfplace
Hi Carl, Who's oil manifold is that?
Really cool lookin deal, I like it a lot better than the usual one that sticks straight up & ends up about in the center of the alternator
Mike
Lewis Racing Engines
4axis CNC block machining
A tour of my shop
The Dyno
And a few pics of the gang
John Wayne
A tour of my shop
The Dyno
John Wayne
