I will have to add a list of different type engines and what a reasonable VE range would be.
Stan
Well, in a drag race car you don't run them at peak TQ, so the spread only impacts ideal stall speed.
Cool, giving a lift figure at min pv clearance is really just working toward the same as Camking is asking on valve drop figure. Knowing at what lift you have min clearance just helps to know where in the curve you can add lift. You never have pv contact at full lift so you will be able to have more net lift and more area under full lift than you do now.
Exactly !!hoffman900 wrote: ↑Fri Feb 23, 2018 9:27 pm If you have the time luxury, giving valve drop to your cam designer is always worth it. Why not use up all the real-estate if you can?
Had the same thing happen on my engine that was dynoed a few weeks ago. It happens to be a 438W as well but that has nothing to do with it unless you are running the same manifold. Finally had to richen one bank to get them equal. I suspect it is in the manifold. Was thinking about trying a "spivy" on the boosters but ran out of time.Steve.k wrote: ↑Sat Feb 24, 2018 10:34 am IMG_2275.JPG. Guys this was run before our highest. We switched from c12 to torco 112 oxy fuel on these. Notice one side uses less fuel. We tried adjusting float levels to get back to the same. Wouldn't change. We mic'd jets all equal. Any ideas what caused discrepancies?
