Rick360 wrote: ↑Fri Mar 23, 2018 1:36 pm
Gary,
What type bench do you have?
Rick
SF110, I included that in a question to you a page or 2 back. Just what I could afford years ago so I wasn't porting blind.
Dennis Wells of Wells racing helped me a lot to get started and made it clear that if I got serious on professional porting that I would need a big boy bench to see the effect of small changes such as valve seat variations.
So far when my heads are flowed on a SF600 the variation is a cfm or 2 of what I got from my bench. The 600 is what my machine shop guy uses as with most here locally.
Gary,
Rick
If your flowz compares close to a SF600 then that's fine. No reason to do any more. The biggest potential error in your setup is getting bad information flowing at 8" or 10" wc instead of 28" or 40" or 50"wc.
28" will tell you wrong sometimes but the odds go up when flowing at 8 or 10", especially when trying to get that really good mid-lift flow.
Gary,
Rick
Rick
Yes thats why I always had my #'s checked on a 600, with my minimal experience I wanted to make sure I hadn't totally screwed up.
digger wrote: ↑Fri Mar 23, 2018 6:25 pm
Maybe we should not worry about calibrated dynos, I mean they all read a bit different anyway and as long the the power goes up all good right...
From what I saw from last years EMC, the guys were basically duplicating the numbers they saw at home, so you had multiple people from different states using different dyno's and then getting matching results on the same dyno.
If you were only trying a few things to see if it improved power then it probably doen's matter but if you needed accurate data for power changes then it does.
cspeier wrote: ↑Fri Mar 23, 2018 10:13 am
If either of you two would spend more time digesting rather than proving things wrong, you would both be better at what you do. FACT
groberts101 wrote: ↑Fri Mar 23, 2018 10:53 pm
Umm.. not learning anything here.. can everyone quit being so stingy with the head porting lessons?
Tech on a Tech forum?... Sherly you jest!
steve316 wrote: ↑Fri Mar 23, 2018 1:07 pm
If it is not some sales pitch them why does it have to be calibrated to the max; as long as your making gains on your bench isn't that what counts?
You are right Steve, until you get your crap in a small pile and then you have pros saying your bench is as happy as a kid in a candy store. The other side of the coin are the people who say cfm and port energy mean nothing. They usually get the best flow per cc of port by the way. The misinformation is interesting. For the guys who made more power with the lower port energy heads the higher port energy heads were TOO fast for that application. Chad is right shape is king, get the shape right and you can get a fast port with low speed differential from floor to roof and the whole port just works better.
Carnut1 wrote: ↑Sat Mar 24, 2018 11:49 am
With all due respect, this could easily be perceived as misinformation right here. Have you tested and confirmed this? Or is this regurgitation? Sounds good though I guess.
Interesting how there is a triumvirate who knows all and will tell almost everybody that they are wrong but never posts how or why something should be done.
Stan Weiss wrote: ↑Sat Mar 24, 2018 1:13 pm
I think it should be live video chat, it would drastically change the conversation.
