After working with a number of manufactures and at a number of proving grounds I can attest to this statement. Being that this site has a number of engine builders I would assume they have seen the same thing. Some people can break an anvil. I won't go into issues I have seen or how issues not seen during testing pop up just a few years down the road. Two racers can both start with identical engines and within months one will have a pile of rubble while the other walked away with the prize money.peejay wrote: ↑Sat Apr 28, 2018 8:22 am "Field testing" can not do the kind of abuse that owners do. Manufacturers will have vehicles out on the road testing almost 24 hours a day gathering data, they will do 240 hour WOT pulls with complete cooldowns every so often so the pull can start from a subzero engine, all sorts of "abuse"... but I don't think they ever idle an engine for extended periods, or do those dyno tests with the engine two quarts low of 6 month old sludge in the oil pan. Heavy load testing is "sexy" but the real abuse happens at the low end of the scale and it is hard to test for that because you can't really condense five years of that kind of abuse into a couple weeks.
That being said, I did not have the opportunity to do extensive long term testing on the Ecoboost vehicles, but the testing I did I was generally impressed. I did see one turbo failure and another we put holes in a full set of pistons, but that was in early testing a couple years before the vehicle and powerplant were coming out. As I say, buy what you want to buy, then maintain it like it is the last thing you will ever buy.
Paul
