LS cam bearings
machinedave
LS cam bearings
Post by machinedave » Wed Jun 06, 2018 6:27 pm
I have been having trouble with LS cam bearings in some Aluminum blocks. It seems to be #3 that is causing the most hassle. I use Durabond CH-10 for the small housing bore older blocks and durabond CH-25 for large housing bore newer blocks. They feel just fine going into the housing bore but the cam will not go in. Anybody have any ideas?
BillK
Re: LS cam bearings
Post by BillK » Wed Jun 06, 2018 7:17 pm
Dave,
I havent had a problem except for the last two I did. I just did two for the local Chevy dealer. They were the 427 Vette blocks with a strange rear bearing with a half moon cutout in the bearing. They all were fine except for the back one. I had to do a little scraping on it.
One thing I have noticed for sure is that the oem bearings, which are a split type like Clevite, seem to leave a scar in the cam bore right where the bearing split is. I take a sanding roll and make sure to get rid of that "scar" If you dont get rid of the scar it can distort the bearing for sure.
Also..... seems like the aftermarket cams are a little bigger than the oem ones. I always tell my customers to bring me their cam to try. I have a stock one that I use but have had one come back for some fitting after they tried their aftermarket cam.
And .... if you are not aware of it the bearings have all been upgraded to the wider ones. I forget the Durabond number right off hand.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
CGT
Re: LS cam bearings
Post by CGT » Wed Jun 06, 2018 7:39 pm
I had problems finding a thin enough rubber sleeve for my tool for LS's. It tended to wanna roll the leading edge of the bearing up a bit. Which the aftermarket cam bearings are more susceptible to because the have much more chamfer in them than the OE bearings.
"If you pick up a starving dog and make him prosperous, He will not bite you. This is the principal difference between a dog and a man"
BillK
Re: LS cam bearings
Post by BillK » Wed Jun 06, 2018 8:22 pm
Glad you mentioned that. I think if you look at the blocks themselves they only have a slight chamfer on one end of the bore. I am pretty sure I have been putting some of the bearings in from the back side because of this. I have the old style K-Line tool with the rubber orings and it fits fine.
Bill Koustenis
Waldorf Md
machinedave
Re: LS cam bearings
Post by machinedave » Thu Jun 07, 2018 9:23 am
Dave,
Thanks. I do clean up the scar with a half round file. I'm going to pull them out and measure the housing bores. The original part number was a CH-23 and the one i always use is the updated wider one is CH-25. Just to solve my curiosity I'm going to pick up a CH-23 and measure them and compare to the CH-25.
machinedave
Re: LS cam bearings
Post by machinedave » Thu Jun 07, 2018 9:28 am
Thanks. I'm using a Durabond camshaft installer tool. With only the #3 bearing installed, I tried installing the cam from the non hammered side and still wouldn't fit. I have several used test fit cams that normaly fit fine that also wont enter.
CGT
Re: LS cam bearings
Post by CGT » Thu Jun 07, 2018 10:07 am
Sounds like your going to have to get ugly with it. I've had to on a couple. Just make sure no one is looking :lol:
Yeah, I've noticed that as well.
tjz450
Re: LS cam bearings
Post by tjz450 » Thu Jun 07, 2018 10:12 am
I had trouble also, with the wide bearings, cam wouldn't go in. Switched to the narrow set and the cam slid right in. Gen 4 block, both cam sets were durabond. The wider bearings seem to need a perfect alinement installation done. The cam tool mandrels that hammer-in, may not be good enough.
A_VAS
Re: LS cam bearings
Post by A_VAS » Thu Jun 07, 2018 12:25 pm
I've been 'relieving them' often to get cam in. the CH23P or 25P series seem hard enough that a Brush Research ball hone will clean them up without smudging. I find this easier than scraping
machinedave
Re: LS cam bearings
Post by machinedave » Fri Jun 08, 2018 3:27 pm
So I removed the CH-25 wide bearings, reinspected and measured the housing bores. #1 is 2.3470" #2 is 2.3271", #3 is 2.3066", #4 is 2.3272" and #5 is 2.3470". I was happy with the housing bore measurements so this time I installed the narrow CH-23 bearings. The cam fits perfectly now. I wish I would have thought about measuring the bearing ID while it was still in the block. I do have another aluminum block here with exactly the same issue so I will measure the ID before I remove it from the block.
exhaustgases
Re: LS cam bearings
Post by exhaustgases » Fri Jun 08, 2018 3:54 pm
I wonder if the manufacture is not sizing some of them properly. There is always the old notched reamer cam trick?
modok
Re: LS cam bearings
Post by modok » Sat Jun 09, 2018 2:36 am
Measure housing bore, check bearing thickness, should be all you need to compare.
I compare the thickness of the old bearing to the new bearing quite often.
Expanding drivers definitely not as good.
Use a solid driver if possible. Guide OD same as cam, driving step .030 smaller than housing.
Glen Urban
CGT
Re: LS cam bearings
Post by CGT » Mon Jun 25, 2018 10:03 am
Just had an ugly fight with cam bearings on my LS3 project. But I won! Sometimes it goes well with these LS's, sometimes it don't. #-o
Turbo231
Re: LS cam bearings
Post by Turbo231 » Mon Jun 25, 2018 11:54 am
I have been told by a couple of people that the LS cam bearings from the factory are align honed to size after insertion because of shift in the aluminum blocks. This is why you can get some replacement bearings to work and some not. It depends on how much bore shift your particular block has. Can anyone confirm this and do machine shops that realize this also hone them to fit?
CGT
Re: LS cam bearings
Post by CGT » Mon Jun 25, 2018 11:59 am
I believe this to be true. Not uncommon at all to see new or barely run ls's with gold showing through on random spots on random bearings, like they had been honed with bearings in.
