472 & 500 Cadillac Engine Tales
Re: 472 & 500 Cadillac Engine Tales
The mid 90's viper 488 made 450 hp at 5200 rpm and it would do 160 in about a half mile, so put a good 6 speed behind that cadillac and gear it right and go have some fun.
BORN RIGHT THE FIRST TIME
I was wondering if that was possible.
He doesn't have the crank out yet.
I think he is struggling with loosening the main cap bolts (he weighs about 90lbs), waiting for him to discover leverage pipe on his own.
He did manage to get the head bolts off.
Looks to have original pistons with the largest rectangular dish I have ever seen. Engine is 1972.
If anyone can suggest a good piston for that engine please do.
If anyone has worked out the piston that works with a BBC rod, I would be interested to know that too.
Last edited by SchmidtMotorWorks on Fri Jun 29, 2018 2:39 pm, edited 1 time in total.
Call marine crank, I bet they have done it, if the crank is steel it will need to be hardened. BBC rods are cheap and he'll need to buy pistons anyway. I read long ago that the blocks are very hard and some show little wear after 100000 miles. And the word was if you run high compression or nitrous you'll need studs and orings.
I worked at Cadillac Motorsports Development back in the 90's. Spent countless days putting in valve guides and machining intake manifolds. Larry was different to say the least!
Doesn't a 1d sim figure out what Pistons to use? Lol. Sorry, couldn't resist. Just being a smartass in good funSchmidtMotorWorks wrote: ↑Fri Jun 29, 2018 2:28 pmI was wondering if that was possible.
lolFrankshaft wrote: ↑Fri Jun 29, 2018 4:27 pmDoesn't a 1d sim figure out what Pistons to use? Lol. Sorry, couldn't resist. Just being a smartass in good funSchmidtMotorWorks wrote: ↑Fri Jun 29, 2018 2:28 pmI was wondering if that was possible.
Those are soap dish pistonsSchmidtMotorWorks wrote: ↑Fri Jun 29, 2018 2:28 pmI was wondering if that was possible.
I'd skip the plans for bigger cubes, there aren't any heads to support them.
KB makes a couple cheaper Hyper pistons. If you use 455 olds rods then deck the block a little you will be better than using the stock 500 rods.
I forget what needs to be done to the 455 rods but its not much.
540 with a T-ram, 600 ftlbs at 5000rpm, lol.
I always wanted to B&S a 500 Cad. engine out to like 550 or so inches just for fun.
I figure the big engine as light at it is would be great in an A/F/X car.. Since it is wide, it might be a bitch fitting it in them, but ---
I would build it for T and not rpm.. Set the cam at say a 210 to 214 then 5,000 rpm and max. lift it!! And then fight the valve train problems...
Add a set of something like 2.42 reg's and highway drive it.
I saw this Cadillac run at several meets at the now closed one mile standing start land speed racing track in Ohio...I talked to the builder/driver who seemed quite knowledgeable. it's a 500 Caddy with all the good stuff and a turbocharger...Full electronic engine management....Car ran consistent 180 MPH...That a shitload of metal to push that fast...
He also blew up several engines and was considering an LS swap...
yes Mr. Sean Mote....I haven't met too many people nicer than this guy..Truckedup wrote: ↑Sun Aug 05, 2018 6:47 pm I saw this Cadillac run at several meets at the now closed one mile standing start land speed racing track in Ohio...I talked to the builder/driver who seemed quite knowledgeable. it's a 500 Caddy with all the good stuff and a turbocharger...Full electronic engine management....Car ran consistent 180 MPH...That a shitload of metal to push that fast...
he runs the high port heads and intake. I have his old set of standard port alum. heads on my engine now.
I had a 472 I put in an '88 Monte Carlo, ran high 13's completely stock, with street tires. I then built a 542" by offset grinding the stock crank to 4.58", which I think was the max you could do and still use a BBC rod bearing. I used 6.8" BBC rods, custom Ross pistons and total seal rings ( 440 oversize I believe). Performer intake, solid cam and T&D shaft rockers (don't remember which ones). Was supposed to build some headers for it, but with stock manifolds, it wasn't much faster than the 472, all done by 5500 rpm. Great for driving around town but lost interest and sold it. 383 SBC I built next was way better. 472-500 blocks had high nickel content, didn't wear too much, and were supposed to be fairly light, alittle heavier than a sbc.
Fiadillac....dangerously unsafe to drive.
Mark
Mechanical Engineer
Mechanical Engineer
Not a bad motor ... I have been building them for 30 years ... stock is 13 degree valve angle but you need to fix the port entrance .. main caps can use some help as power goes up ...it needs better valve train.. a good intake helps alot ... I like it as building a BBC is to easy and you don't learn
