Epoxy to fix excessive bowl cut
user-30257
Re: Epoxy to fix excessive bowl cut
Post by user-30257 »
vwchuck wrote: Mon Jul 16, 2018 3:46 pm Hmmm maybe I will epoxy this thing. It is a production daily driver 5 valve per cylinder head. This is on the tiny little intake valves.
If It is a daily drive.. just run it. If this is a very aggressive racing piece. Fix it.
vwchuck
Post by vwchuck »
If I was to pull the seat out I would weld it up and do it proper but it is not worth it on this head.
Thanks for the help guys.
blown265
Post by blown265 »
How much horsepower is being lost from a bowl/seat ridge in the wrong flow direction? Is the loss mostly at peak rpm?
(for the OPs engine, or in small block terms, 1.5hp/ci, with a 40thou mismatch)
Thanks
Paul
