importance of and improving power curve
77cruiser
Re: importance of and improving power curve
Post by 77cruiser »
randy331 wrote: Mon Sep 03, 2018 11:16 am
77cruiser wrote: Mon Sep 03, 2018 10:16 am I'd be curious to see how much the 1 5/8 step headers were hurting you.
It may not be as much as we think.
I may be disappointed when I buy/build a nice straight 1 3/4 x 1 7/8 step header and gain 7 HP but loose 5 Lbs tq. But you never know,.. could be 25 HP.
How about 4-2-1 headers?
Jim
randy331
Post by randy331 »
77cruiser wrote: Mon Sep 03, 2018 11:47 am
You see them some on pulling trucks. Pro stock trucks is where I've seen them so far.
A 4-2-1 header may be easier to fit in the chassis. There ain't much room on the drivers side to fit them. Driveshaft and driveshaft loops a differential etc.
A 4-2-1 may help the power curve and the power curve seems important in pulling trucks for sure.
77cruiser
Post by 77cruiser »
randy331 wrote: Mon Sep 03, 2018 12:02 pm
When I built my 4-2-1's they weren't too bad to build, a lot easier than 4-1. Calvin Elston told me way easier & less tubing plus easier fit. First time I ever tried anything like that.
http://www.speedtalk.com/forum/viewtopic.php?t=41836
Jim
randy331
Post by randy331 »
77cruiser wrote: Mon Sep 03, 2018 12:19 pm When I built my 4-2-1's they weren't too bad to build, a lot easier than 4-1. Calvin Elston told me way easier & less tubing plus easier fit. First time I ever tried anything like that.
Could you spec me a try Y ? I want more TQ at peak TQ more HP at peak HP and more power above peak HP.
In other words I want more power from 5000 rpm up to 9800 rpm.
Can you spec me that header ?? LOL
77cruiser
Post by 77cruiser »
randy331 wrote: Sat Sep 08, 2018 10:24 am
No I'm a old rookie, I bet you have an idea of what you need. Pipemax would be a start.
Jim
Frankshaft
Post by Frankshaft »
77cruiser wrote: Mon Sep 03, 2018 12:19 pm loo
I would try and move the peaks up. If it runs up there, I would try and get the peak closer to where it runs. Pulling isn't my thing, but I still build a fair number of engines or do heads for them, and evertiime we moved the peaks up, it pulled better.
user-30257
Post by user-30257 »
Dyno, and change primary lengths, collector lengths and merge type. Slip style headers are great for tuning the curve.
randy331
Post by randy331 »
Frankshaft wrote: Sat Sep 08, 2018 11:18 am
I'd like to raise the peaks some, but I've seen the engine as high as 9600 and as low as 5200 during full throttle pulling.
If you can keep the truck hooked up at the end of the pull, TQ around peak TQ seems to help too.
With the ones I have info on, seems once they get below peak TQ rpm, it's lights out in a hurry.
I have a few things I'm planning on doing to try and raise the peaks.
Be nice to have it better everywhere.
CGT
Post by CGT »
randy331 wrote: Sun Sep 09, 2018 4:19 pm
What do you think about trying more lift? That could possibly be better everywhere in that rpm range....
steve316
Post by steve316 »
Increasing intake track cross sectional area will aid in moving peak HP up in the rpm range. If you have room to take max cross section taper to 4.5 in to 5 in at plenum should increase spread from peak TQ to peak HP. Every time I increased taper in intake manifold it helped. Just something to consider.
randy331
Post by randy331 »
Pulling trucks,.... :D again.
I know you guys are tired of pulling truck talk. :D
Well,.... looks we're in tear down mode for some winter up dates.
Wanted to see a big carb on the 421 for a test hook, so I got a 1.92 venturi x 2.250 throttle bore carb from Mark to try, but the track wasn't good,.... so not sure. Wanted it to be hooked up hard and see the 421 brought back down to 5000 rpm or so, but didn't happen. No traction. Spun out at part throttle. Wanted to see if it'd stay on line like the Braswell we been running, but.....not a good test.
So,.... how do you size a carb for a pulling truck?
Got some other pulling truck engines to do/up grade over the winter, and 2 more besides us need carbs.
Guess I could start a new thread on them.
3 big blocks and our 421 small block are up for some work.
randy331
Post by randy331 »
CGT wrote: Mon Sep 10, 2018 8:56 am What do you think about trying more lift? That could possibly be better everywhere in that rpm range....
This,... from the guy who said not to change things in the valve trian cause it seems happy now ??? :lol:
Lift is on the table for change for next year. :D
CGT
Post by CGT »
Frankshaft
randy331 wrote: Wed Oct 17, 2018 10:22 pm
How about a 30 degree radius intake seat? For big low lift flowz. And some major port bias? I think that would crank the port energy thru the roof.
CGT
Post by CGT »
Lift could possibly calm the valvetrain even more.....depending on how you go about getting it..
