5/16 Carr rod bolts
5/16 Carr rod bolts
What type of application would such a small rod bolt apply to would this be for a 4 or 6 cylinder with not a lot of hp and rpm.Thanks just curious??
Re: 5/16 Carr rod bolts
Are you talking about Carrillo bolts? The ones that were made by standard press Steel or SPS?
I recall reading 20+ years back that when Cosworth got into the US market, they developed a SBC rod that exceeded all requirements using just a 5/16" bolt, but it was a commercial failure until they upped the bolt size, because no one trusted such a tiny fastener. Could still be some of them around I guess...
Carrillo has this bolt size in there catalog and I think arp has a 5/16 rod bolt also and the ones that I saw where carr sps 60
- New Member
We have run them on the 4 cylinder naturally aspirated engines for many years. Steel rod a little over 6.0” 400g, 260g piston, 4.173” stroke, 10,800rpm. Never had a bolt/rod failure.
Right, now I remember, 11/32" and then went to 3/8".
And way overkill was the BB rod forging made for a SB with 7/16" rod bolts.
Warp Speed, you HAVE to use 3/8" rod bolts with the setup you are using currently correct ??? Mark H.
Australian V8 Supercar 5 litre SBF's use or have used 5/16 rod bolts. Up to 650 hp at 7100/200 for 3000 km.
What does the CARR stand for ? Always figured it was short for Carrillo? Mark H.
