My engine without the blower peak hp is at 6200
My engine a SBC 400 without the blower peak hp is at 6200 with 470 HP. just where Comp cams said it would peak , The cam is a 248/260 114 cl. If it was a 302, would a rpm be higher where the peak is...Its 8.0 to 1 by the way Oldhead
Quicker then most
Re: My engine without the blower peak hp is at 6200
With 22# of boost its 1004 HP at 7000
Quicker then most
Ok I'll pat you on the Back as I guess that's what your looking for with this post , no?
The simple math is 400/302*6200= 8212rpm is about what you'd expect...hp would remain about 470, new torque = old Torque X 302/400. It won't be exactly those numbers but they would get you in the ball park.
Mark
Mechanical Engineer
Mechanical Engineer
Your guess pat on the back is wrong, Others are making 1500 hp with other SBC, I would like a answer to the question. Oldhead
Quicker then most
the only question i see that you asked is, will the rpm peak be higher with the smaller displacement engine given the same cam, and the answer is yes. based on your last post, i think youre looking for something else, but thats the answer for what was asked.
You answered my question and I thank you, Not looking for anything else, Any idea on how much higher in RPM? Oldheadlefty o wrote: ↑Sat Oct 20, 2018 11:04 am the only question i see that you asked is, will the rpm peak be higher with the smaller displacement engine given the same cam, and the answer is yes. based on your last post, i think youre looking for something else, but thats the answer for what was asked.
Quicker then most
8212....as I posted for you.
Mark
Mechanical Engineer
Mechanical Engineer
