Hi guys
Looking to convert an already assembled nitrous engine into a blower motor. 9.5 SBF. 4.0 x 4.125
Possible issue at hand :
6.250 Rod ( Callies Ultra I beam )
2" Crank Journal ( Callies Magnum )
Its going to be an E85 Engine. I plan to have the compression between 10.5 and 11.5 and turn 8000 - 8300 RPM - HP Level 1500 ~
Is that long rod and small journal going to pose a issue getting this done ?
SBF Boosted Rod Ratio
Re: SBF Boosted Rod Ratio
The rod to stroke ratio of 1.51 isn’t bad. I wouldn’t expect issues from that.
A bigger concern may be crank strength with a 2” journal at that stroke (not much overlap)
However, you’re using a good crank and rods, so it’s something I would attempt already having the parts.
Since the parts have been used and maybe hard, I’d want to mag everything to check for cracks.
Aftermarket block I hope?
Everything is brand new un used. Block is a Dart Iron Eagle.Keith Morganstein wrote: ↑Tue Nov 06, 2018 5:47 pm The rod to stroke ratio of 1.51 isn’t bad. I wouldn’t expect issues from that.
