How to figure cam overlap?
econo racer
Post by econo racer »
When reading a cam card how do I figure this out? Thanks!
F-BIRD'88
Re: How to figure cam overlap?
Post by F-BIRD'88 »
Add up in,ake and ex duration and divide by 2.
Divide that result by 2 again and subtract lsa.
Multiply that x2. = overlap.
BradH
Post by BradH »
# of degrees the intake opens before TDC + # of degrees the exhaust closes after TDC
Example:
Intake opens 30* before TDC
Exhaust closes 30* after TDC
Overlap = 60*
Keep in mind that it's going to depend on where on the lobe you're measuring the duration, too. The overlap measured at effective seat duration is going to look much larger than if measured at .050" lobe lift.
I hope this helps. - Brad
Newold1
Post by Newold1 »
F-BIRD88 :
I am having issues trying to make your formula work?
A cam has 232 @ 50 intake duration and a 242 @ 50 exhaust duration with a 112 LSA
Using your formula as given - 232 + 242 divide by 2= 237 divide by 2 = 118.5 - 112 = 6.5 x 2 = 13 degrees overlap ?? seems a bit small ??
PRH
Post by PRH »
Overlap is “usually” associated with the advertised duration.
In the above example, 13 is correct for overlap @.050.
I do it similarly to the formula you used if I don’t know(or want to calculate) the open and close points.
Duration for intake/exhaust added together, divide by two, minus two times the lsa angle.
232 + 242 = 474
474/2= 237
237 - (112 x 2) = 13
Newold1
Post by Newold1 »
Got it, forgot to think advertised versus @50.
07GTS
Post by 07GTS »
can be a noticeable difference mine was about 5 deg at .050 but at .006 its 57 deg overlap
CGT
Post by CGT »
:lol:
pastry_chef
Post by pastry_chef »
Some time back I composed an excel, it backwards calculates from overlap and LSA to int and exh duration.
https://www.speed-talk.com/forum/viewtopic.php?f=1&t=54556
Mike R
