randy331 wrote: ↑Mon Nov 26, 2018 4:56 pmGuess that would make a difference. lol
We have to use factory Iron heads. 026-990 casting rec ports mostly.
Prepare for disappointment. I have ported one set of 990s for pulling. I will not touch them now. They are so thin in areas. Inconsistent as well. I did a 2.25 with 11/32 stem. If I had to do it over on my own I would have done a 5/16 stem. If I had a big bore I would go 2.30 valve or if you notched bore well. I would make the bowls as big as you feel comfortable which will not be much maybe 96% of valve.
