Anyone have an old Arias piston catalog or info on an old Arias piston number? I have a N.O.S. set I'm trying to identify.
Thanks!
Vintage Arias pistons
Re: Vintage Arias pistons
What's the compression height on those Pistons and there diameter + .008"?
Contact Elmer Cerritos at CP-CARRILLO 949.567.9000 for information on your Arias Pistons. Elmer was in the sales department of Arias for several years and is now at CP as a result of CP buying Arias a few years ago. He probably has the resources necessary to find info on all Arias products.
Bill
SAE Member (30 years)
How old are we talking ? 10 years, 20 years ? I have a couple of old Arias catalogs at the shop. Post the part number and I will take a look. If you dont want to post the number then PM it to me.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
www.enginerepairshop.com
Waldorf Md
The pistons are L5210+60's. They measure 4.058, have a full dome, comp. ht. is about 1.808. Rings are 1/16/1/16/1/8", pin diameter is standard .927.
Thanks!
Thanks!
Should add: these are '70's vintage, N.O.S. in the box. I believe them to be 302 Chevy small block (4.060X3.00). Thanks!
I've got a listing of 1980s Arias pistons. None start with 'L' . Either E, S or b. Closest to your # is E4210 +030. 302 Chev. Flat top 9:1.
- New Member
I just picked up a set of NOS Arias pistons. I already talked to Elmer and he cant tell me based on the part # S-4306. All I know is they are 30 over dome tops. Geoff2 is this part # in your book?
You are in luck. S-4306. Suits 454 Closed Chamber heads, 12.5:1, come in 030 & 060.
- New Member
