Yes, and what was the reason arrived at why the 1.5 rings didn't work there, when they obviously work well in many other applications?NORSK wrote: ↑Sat Mar 02, 2019 1:54 pmDid you read my previous comments?Momus wrote: ↑Sat Mar 02, 2019 1:51 pmHow is this conclusion arrived at? Data from ring manufacturers or testing?Norsk wrote:
A taller oil ring package also works better for oil control
Low height oil rings offer obvious packaging advantages and less chance of flutter.
I have smaller bore stuff here with 3 piece oil rings that are 1.5 mm high.
Are thin piston rings worth horsepower?
Re: Are thin piston rings worth horsepower?
They do work,just not as long as a taller ring package before they get clogged up.
I assume you deal with motorbike engines since you mentioned small bore stuff,they do not see the same mileage as a car street engine.
Anyway,the topic here started off with if there was an advantage with thinner piston rings regarding if there is any power to be made
A thinner ring has less friction surface obviously,and yes thinner rings gives more space for a tighter ring land with all the advantages that brings along.
However,as Mark O Neal mentioned,if the oil ring package gets smaller the oil rail tension has to be higher
So the way i see it,if we use a 3mm package with same height on both rails as in a 2mm package,then the tension of the 3mm rails can be lower and the friction will be lower
So whats the point in using a 2mm versus a 3mm UNLESS there is space issues
This is the part i don't understand
I see you mention ring flutter,is that really an issue for a oil ring?
