LoganD wrote: ↑Thu Mar 14, 2019 9:39 amFlow is good. When someone goes to buy a better cylinder head for their engine, do they look at it and say, "Well, this head has more low lift flow than my stock head, must be garbage then!". No, people swap to cylinder heads that have better low lift flow and gain power ALL THE TIME. The heads also have better high lift flow! How come they don't cancel out and gain zero power?
You are making a change that happened to decrease low lift flow, and your conclusion is to say that low lift flow is bad. Instead, you should be investigating what else changed when you decreased low lift flow. We have thousands upon thousands of available dyno tests, magazine articles, and OEM test data that shows a better flowing system makes more power (within reason).
Maybe the dynamic flow improved, but obviously a flow bench doesn't show that. In an engine the valves are opening and closing, it's not a static flow condition like a flow bench. It's possible that, under the conditions the engine is running at, you improved flow and don't even know it. This does not mean low lift flow is bad, it just means the way people are measuring low lift flow is bad. You have to be more specific and get to the root of the issue.
I'd share some data if I could, but the NDAs I work under are pretty ironclad. Take that as you will.
You answered your own problem. If you reduce low lift flow, you have to know WHY you are doing it. I know why I do it. In fact, I don't really care what the actual flow number are. They make little difference in the actual power of the engine.
It's how you use a flowbench that counts. Every single time I've used steeper that 45 degree seats clear up to 55 degrees I've made more power. Every time. That's N/A, blown alcohol, nitrous, several turbo combos and a bunch of circle track stuff. There is more to cylinder heads than flow at 28 inches.
Again, a reduction in low lift flow is the least of my concern. If I use a steeper than 45 degree seat and lose flow, even lose flow to max lift, I do not care. I care about the end result.
