Brodix Tract 1s.
Actually, we don't.Stan Weiss wrote: ↑Thu Apr 18, 2019 11:10 pm Would be interesting for Warp Speed / Jay to weigh in on how much they look at BSFC since MPG does at times come into play.
Stan
His new converter showed up today, so yes, he'll get the right converter. LOL
Hope he's ready to hang on. With 100hp more and a good Coan stalling right should make for an interesting first pass.randy331 wrote: ↑Fri Apr 19, 2019 5:44 pmHis new converter showed up today, so yes, he'll get the right converter. LOL
Sent the dyno sheet to Coan and had them make one.
Tried a 1" taper spacer and it was worth a very small amount of power, so we didn't test others.
It's making enough power for a factory block.
He'll try whatever I or his chassis guy suggests.
I'm suggesting get in and see what it runs like for now.
If he is like most racers he will be happy the first night out and then his only thought will be how to go faster... That gets a lot harder now.Rick360 wrote: ↑Fri Apr 19, 2019 5:54 pmHope he's ready to hang on. With 100hp more and a good Coan stalling right should make for an interesting first pass.randy331 wrote: ↑Fri Apr 19, 2019 5:44 pmHis new converter showed up today, so yes, he'll get the right converter. LOL
Rick
If this thing has the grunt the dyno sheet says it won’t need a 7” to get 6200 stall
I think it will. But it would have been nice to see a dyno pull that high to be positive.KnightEngines wrote: ↑Sat Apr 20, 2019 10:41 am I'd agree with coan, you don't want the rpm kept artificially high by the converter, you want it locked up & not slipping & sapping power to keep rpm up.
If the motor would drop below stall speed on the change without the converter keeping it up then you're wasting power.
If you think it'll run out to 8000 & not drop below power at 6500 then maybe it could use more stall.
It is very possible to have too much converter.
