engine combo
engine combo
how does this combo look. all motor class 3400#camaro 565ci bbc dart 24 degree 370 cnc oval port heads the heads flow 420 in /319 ex @ 800 lift cam is bullet roller 7/4 swap 807 lift in /775 ex dur is 283 in/293 ex@ 50 th. on a 114 ls .cp 14.5 -1 pistons ;grp alum rods,callis crank;super victor intake full port work .1150 carb,crank trigger; lemons headers 2.1/8 - 2 1/4 stepped with 4'' merge collectors and borla race mufflers ,coan powerglide180 stright cut gears 9'' 5800 conv 9'' 4.56 gear 28/10.5 slicks hope this is enough info. need to run 5.60 in 1/8 mi /124 to be competitive thank for the help.
You are going to need to make about 1000 hp at the rear tires with a 3400 lbs. car to get where you want to be. While what you have looks to be a good combonation, i don't think it will make enough power N/A to get you where you want to go.I think with a Big Chief style head, you could get there, but it would even have to be a pretty stout piece.
Shawn
Shawn
