Is there a adapter out there to mate a 23 degree header to a 18 degree head with the straight 6 bolt pattern? All I can seem to find is STAHL pattern.
Wrecked our dirt car and am having a hard time finding a set of 18 degree pattern headers. Thanks!
18 degree head to 23 degree header
- New Member
Re: 18 degree head to 23 degree header
Schoenfeld has several headers that fit 18 degree heads.tracyracin wrote: ↑Tue May 14, 2019 1:08 pm Is there a adapter out there to mate a 23 degree header to a 18 degree head with the straight 6 bolt pattern? All I can seem to find is STAHL pattern.
I have seen spacers to allow fitment of "spread port" 23 degree headers the the 18 degree heads but, you needed to drill the 18 degree bolt pattern in them.
You can always cut the flange on the 23 degree header, grind away and make it fit.
Joe Facciano
- New Member
Okay I think I have myself confused. What I really need is a set of spread port headers I think. I run a northeast modified and when I went to bolt a normal set of headers to the engine the pattern was too narrow.
Anything like these?
"do it right or do it right away"
http://www.motionmachineinc.com/
https://www.youtube.com/watch?v=ZgIZbveknDs
Call up Schoenfeld. They have more than a few sets of headers available with a spread port exhaust flange. On a lot of their ads, you'll see:
All you have to do is ask em about it, even if you don't see it on their website.
Available with CNC laser cut flanges to fit Brodix 18º spread port, Stahl, standard Chevy 18º, Allen Johnson, and Pontiac 867 heads add $60.00.
