Hey thanks for the input.JoePorting wrote: ↑Wed May 22, 2019 2:05 am Why do you think you are having issues with the carb? Seems like the motor is topping off at around 5700. I'm thinking valve springs. What's your valve spring pressures and what's the recommended valve spring pressures for the cam?
What sort of power were you expecting? 738hp isn't too far off what I would think this combo could do. I'd think maybe 800hp or so would be really good.
I’ll have to check on the springs… I was thinking that too. I know the seat force is 250 but not sure open. I will note these heads use Jesel shaft rocker with all titanium valves (5/16 intake), and retainers. Should be pretty light. Also, very stiff double taper pushrods ½ at widest area.
I was pretty happy with numbers, but the dyno secession provided no real usable info other then tq and HP. The demon was just a backup carb to trial but ended up the dyno guy wanted nothing to do with the SV1 I wanted to work with. So I felt unprepared for using 4150 Demon. Maybe It’s a good carb?… not sure but after all the dram of a poor dyno secession and quite a few bucks spent on the engine itself, I want to be sure I have the right carb on there.
I really think this should be closer to 800 hp and don’t want to leave that on the table if there is something better. Curious too as to why it fell off so hard just prior to 7000 rpm. Min CSA is 3.12 on the head if I recall correctly.
That’s why I’m reaching out to all the experts on here. I value the insight and experience.
