choosing a roll center height.
Olefud
Re: choosing a roll center height.
Post by Olefud » Thu May 30, 2013 11:22 am
MadBill wrote:It's worth noting that an SLA front suspension can be arranged to maintain a RC fixed Vs. either the ground or the CG, as required to match an axle or chassis-mounted Watts pivot.
Point taken. Still, my thought was that there’s a lot going on with a SLA so it may be the better course to not fixate on the RC parameter alone. It’s good to have a well thought out setup but compromises will be made.
Warpspeed
Post by Warpspeed » Thu May 30, 2013 6:30 pm
My approach to initially establishing some roll centre heights on a new project would be to begin by shamelessly copying an existing car that is known to work well.
That might be a consistent winner in your class.
Or a car of similar size, weight distribution, power, tire size, and usage that some multinational company has spent millions of dollars on R&D developing over a long period.
Make as much as possible adjustable, and use the template car the starting point for your new design.
The original poster is building a tube framed front (mid) engined car for road racing with strong aero.
This has been done many times before, and it is just a case of tracking down a few famous past winners and figuring out what they did and why they did it that way.
Cheers, Tony.
redliner
Post by redliner » Mon Sep 09, 2013 8:26 pm
Warpspeed wrote:More than one way to skin a cat.
It's a bit clearer with a Watts linkage, you can do it both ways.
I am interested in installing a watts linkage on my 4-link drag/street car and your picture of the linkage with the pivot mounted on the chassis looks like the better way to do it on my car because of room constraints. I think I can run a mount down from my upper shock mounting bar ( but how far down? to center of pumpkin at ride height?) and mount the outer ends of the bars to the backbrace(bolts centered?) on my rearend housing...follow? Feasable?
Warpspeed
Post by Warpspeed » Mon Sep 09, 2013 9:36 pm
Certainly feasible, I have done it this way myself in the past.
One point to be a bit careful of is ground clearance at full bump.
If the lower end of your Watts linkage ever digs into a speed hump, or concrete curb, the damage could be pretty major.
Cheers, Tony.
redliner
Post by redliner » Tue Sep 10, 2013 5:44 am
Warpspeed wrote:Certainly feasible, I have done it this way myself in the past.
Thanks Tony!
