panel adhesive.......
6sally6
Post by 6sally6 » Sun Dec 29, 2013 11:22 pm
Put in the search block and got zero info.
Need to re-skin rear quarters on a 66 Mustang. Friend of mine recommended using adhesive in stead of welding. No warp...let grinding...less filler...less time...less chance of rust return because of welding and burning away paint...
Anybody tried it......instead of welding a lap joint?
6sally6
bmcdaniel
Re: panel adhesive.......
Post by bmcdaniel » Mon Dec 30, 2013 1:41 pm
Used to be they didn't recommend panel adhesive on stressed body panels, which would describe the rear quarters of a unibody Mustang. Maybe things have changed since then ?
Greenlight
Post by Greenlight » Thu Jan 02, 2014 1:16 am
Try this stuff.
It's stronger than "unobtainium".
http://www.3m.com/product/information/M ... alant.html
Project Greenlight
flyingwedge
Post by flyingwedge » Wed Jan 08, 2014 12:54 pm
6sally6 wrote:Put in the search block and got zero info.
6sally6
>> Reading the 3M description: "strong, allows movement". You need No movement, as in properly welding. flyingwedge. :(
Mike Peters
Post by Mike Peters » Sun Oct 05, 2014 10:43 pm
3M Panel Bond adhesive 08115
spawny
Post by spawny » Sun Oct 12, 2014 4:19 pm
3M Panel adhesive is a very good product but in order for it to work properly you must have very tight tolerances when you pre fit the quarter .If you are using repro parts the fitting will take you a long time and likely not be close enough we are talking millimetres only .As I have been restoring Shelby's and mustangs for 30 years even with NOS or original parts proper cleaning of mating surfaces and welding is your best way to go.
