dzus fasteners
6 cylinder puller
dzus fasteners
Post by 6 cylinder puller » Mon Mar 31, 2014 8:38 pm
Any tips or tricks for using these, I already bought the wrong length. So hoping to get some info on there before I waste more money. Have about .455 inches of material to go through.
Bubstr
Re: dzus fasteners
Post by Bubstr » Thu Apr 17, 2014 1:57 pm
You already learned rule one. Size is important. You need tension on that spring to keep them fastened. Second thing is, don't use them where there is a lot of twist to that panel. Put a tranny tunnel in aluminum floored Gasser back in the day before 12 point cages and stretched more springs than there was. Went to a Rivnut. They are made fo access panels with hinges.
