coil overs
BurkhalterRacing
coil overs
Post by BurkhalterRacing » Thu Oct 30, 2014 9:54 pm
I have a 1980 camaro that I'm building for the X275 class I'm going to a ladder bar coilover setup instead of caltracks.....I'm wanting to drop the rear of the body about 4 inches....I'm also dropping the front 4 inches...my question is how do I drop the rear 4 inches when I install the ladder bar setup?
BurkhalterRacing
Re: coil overs
Post by BurkhalterRacing » Thu Oct 30, 2014 10:17 pm
Like for example the top bar that the top of the shocks bolt to? Do I need to weld it up higher or what?
BurkhalterRacing
Re: coil overs
Post by BurkhalterRacing » Thu Oct 30, 2014 10:50 pm
Shock length?
turtle
Re: coil overs
Post by turtle » Mon Nov 03, 2014 6:53 am
The two ways that I can think of are:
1) change your mounting points. Raise the upper mount, or lower the mount on the rear end, or a combination of both upper and lower mounting points.
2) use a shorter spring and shock combination.
Our Creed: "Where two or more are gathered, there shall be a RACE!"
John Wallace
Re: coil overs
Post by John Wallace » Mon Nov 03, 2014 9:55 am
4" is a lot.
Will you have room for the ladder bar front mounts?
(they will probably be up inside the body floor)
Figure out what spring pressure you need for your car.
Then what height you want to use.
Set/level the body and rear end where you want them in relation to each other.
Then you can put the brackets where you like them.
The shocks will fill the 'void' with however you want the shock setup.
(more travel while at rest, etc)
Basically as some said, the upper mounts will be higher up in the body, or the springs/shocks will be shorter (less travel).
John Wallace
Pontiac Power RULES !
www.wallaceracing.com
BurkhalterRacing
Re: coil overs
Post by BurkhalterRacing » Mon Nov 03, 2014 12:15 pm
Thank you John Wallace I appreciate the info......common sense was telling me that but I had to be sure
