Ladder bar pinion angle. (decoding Rosslers diagram)
forcefed86
Post by forcefed86 » Tue Nov 10, 2015 7:26 pm
So according to Rossler if my trans is pointing downward 2.7 and my pinion is pointing down .5* I should be "ok" If I shim the trans mount up until I have a 2* downward pointing trans? The diagram is slightly confusing to me.
Olefud
Re: Ladder bar pinion angle. (decoding Rosslers diagram)
Post by Olefud » Fri Nov 20, 2015 5:54 pm
I’ll take a crack at it. I think they’re saying that at launch the diff pinion angle changes under load. The differing angles recommended provides” lead” for this. Under power you want both angles about the same -most critically at launch. If the angles differ rear wheel speed pulsates as the drive shaft speeds up and slows.
John Wallace
Post by John Wallace » Sat Nov 21, 2015 8:22 am
According to the diagram, if your tranny is pointing down 2.7º your pinion should be pointing UP 2.7º
Or probably best to raise your tranny to 2º down then your pinion to 2º up.
John Wallace
Pontiac Power RULES !
www.wallaceracing.com
