Page 1 of 1
Ladder bar pinion angle. (decoding Rosslers diagram)
Posted: Tue Nov 10, 2015 7:26 pm
by forcefed86
So according to Rossler if my trans is pointing downward 2.7 and my pinion is pointing down .5* I should be "ok" If I shim the trans mount up until I have a 2* downward pointing trans? The diagram is slightly confusing to me.
Re: Ladder bar pinion angle. (decoding Rosslers diagram)
Posted: Fri Nov 20, 2015 5:54 pm
by Olefud
I’ll take a crack at it. I think they’re saying that at launch the diff pinion angle changes under load. The differing angles recommended provides” lead” for this. Under power you want both angles about the same -most critically at launch. If the angles differ rear wheel speed pulsates as the drive shaft speeds up and slows.
Posted: Sat Nov 21, 2015 8:22 am
by John Wallace
According to the diagram, if your tranny is pointing down 2.7º your pinion should be pointing
UP 2.7º
Or probably best to raise your tranny to 2º down then your pinion to 2º up.
