Fox Body Dirt Track
Gear_Head_1967
Fox Body Dirt Track
Post by Gear_Head_1967 » Thu Apr 28, 2016 11:07 pm
I need input from peoples exsperience using foxbody V8's or other strut cars on circle track applications. Ive designed the Mustang to use coil over springs on the struts in the front to eliminate using the big springs.im using a 3 link rearend setup with a track bar behind the rearend. The top link is a spring loaded AFCO unit that allows the rearend to roll and assist in tractions.
Thanks for the help
englertracing
Re: Fox Body Dirt Track
Post by englertracing » Sun Jun 26, 2016 7:39 pm
Gear_Head_1967 wrote:I need input from peoples exsperience using foxbody V8's or other strut cars on circle track applications. Ive designed the Mustang to use coil over springs on the struts in the front to eliminate using the big springs.im using a 3 link rearend setup with a track bar behind the rearend. The top link is a spring loaded AFCO unit that allows the rearend to roll and assist in tractions.
Thanks for the help
I raced a capri fox body with a 2.5L pinto
rough track
https://youtu.be/ZcAQrHPHy98
better prepped track
https://youtu.be/X4UhuxWuWN4
we werent allowed to do what your doing with the rear or the struts.....
but what is your question about really?
