Hey all:
I found these new mounts the other day, and thought they were pretty neat. http://www.allstarperformance.com/product.htm?prod=772
What are your thoughts about using these in a street stock, in place of Energy urethane mounts? It seems to be a good way to add some rigidity to the front of the frame where we can't add any tubing(like a front hoop)
With a stock frame car, would it be wise to retain the Energy trans mount (TH350) to allow some flex absorption?
I welcome all suggestions.
RR
Solid Mounts or Not?
Racer Roy, they look like a very nice alterative and certainly should strengthen that front crossmember, I would use them with no fears, on that rear mount, I think that urathane rear would give the trans case some flexibility so it doesn't crack, but my experiance only comes from using powerglides on a 1/2 mile good clay track with bite.
trans mount
Never use a solid mount on an automatic transmission
Learned that one the hard way altho it now makes a good mock up transmission because it is very light.
TI
TI
TORQUE RULES !!!!
I always use rubber mounts. Most engines anchor the mounts to the relatively flexible outer water jackets, but the way I look at it, it's silly to put money into precision machining of the block if you're going to start feeding chassis loads through it. And yes, I know Formula 1 cars do it, and they have special blocks designed for it, and I still say it's a bad idea.
As far as rear mounts... I've seen several broken transmission tail housings. The chassis can move around a lot under load, and the aluminum tailhousing takes torque loads it was never intended for.
