CALTRACS ANYBODY 1.3 60 FT'S - MUSTANGS, COMETS,FALCONS?
ANYBODY HERE IN THE 1.3 60 FT ZONE ON 10.5 TIRES 60'S 70'S MUSTANG, FALCONS. MAVERICKS,COMETS? TRUE 10'S 28 X 10 X15
WHAT HOLE LOCATION?
FRONT SHOCK SETTING AND TRAVEL OF SUSPENSION?
TIRE PRESSURE/RIM SIZE?
REAR SHOCK SETTING? DOUBLE ADJUSTABLE? SINGLE? SETTINGS?
AMOUNT OF PRE-LOAD?
THANKS
MIKE S -TEXAS
WHAT HOLE LOCATION?
AMOUNT OF PRE-LOAD?
THANKS
MIKE S -TEXAS
Do it right the first time
I don't have a Mustang, it's a 70 Nova but I'll give ya my settings. I spent some time with John Calvert at the track working this out, if you are having trouble don't hesistate to call John he is a GREAT guy to work with and will offer all the help you need..Ok here goes;
Bottom hole
Full loose Koni SPA1's, 5" of travel (travel is VERY important)
11 lbs, 8' wide wheel
QA1 single adjustable 4 clicks from full loose (video the car at launch to see how hard you are hitting the rear tire), this will help with your setting. In slow motion you could see my tire was hitting so hard the rim dam near touched the track, then when the tire would come back to it's normal shape it would un-load, so we stiffened up the extension to calm it down and it hooks MUCH better.
1/2 turn pre-load
All this is with mid to high 1.30's MT 29.5 x9 stiff sidewall slick, I also have the Calvert racing split monos.
2006 PSCA Mean Street Champion
Good luck with your car!!!
Bottom hole
1/2 turn pre-load
rappracingengines.com
NEWS ...JUST WATCH THE NEWS!
NEWS.THE ONLY NEWS i HAVE IS RAIN...RAIN..RAIN........WILL IT EVER STOP! A MONTH STRAIGHT , EVERYDAY.
MIKE
MIKE
TRACK TIME 7-21-07
I HAD ONE MOMENT IN THE SUN LAST NIGHT, I CHANGED THE SHOCKS AND UNHOOKED THE TRAVEL LIMITERS . THE XCAR DID GOT INTO THE 1.30'S BARELY, RAN 3.96 AT 330 AND 6.15 1/8 MILE, I PUT A LARGER RETURN PILL IN BUT SLOWED UP ON THE MPH.
THE DOWN SIDE IS I PUSHED THE FRONT SEAL OR CRACKED THE FRONT PUMP ON THE C-4 AND PUT FLUID DOWN RIGHT AT THE TURN OFF AND RETURN ROAD, ONE PASS ONLY LAST NIGHT, PULLING TRANS TODAY
MIKE
MIKE
I CALLED ART CARR TODAY
I FOUND A TEAR IN THE FRONT PUMP GASKET. I INSTALLED A AFTRERMARKET BELLHOUSING AND PULLED OUT TWO COUNTERSUNK BOLTS TO DO SO WITH MOVED THE PUMP.........ART CARR ASSURED ME ITS THE GASKET , THE TEAR IS RIGHT NEAR THE HI PRESSURE PORT.
HOPE FULLY HAVE IT BACK IN BEFORE THE WEEKEND AND 6.20 INDEX CLASS THIS WEEKEND AND ALITTLEW MORE TEST AND TUNE
MIKE
MIKE
- af2
Re: I CALLED ART CARR TODAY
Have you actually measured the run out? I had .042 with the aftermarket bell and was happy it wasn't further! I could buy the Moroso part and not have to make two!seefour wrote:I FOUND A TEAR IN THE FRONT PUMP GASKET. I INSTALLED A AFTRERMARKET BELLHOUSING AND PULLED OUT TWO COUNTERSUNK BOLTS TO DO SO WITH MOVED THE PUMP.........ART CARR ASSURED ME ITS THE GASKET , THE TEAR IS RIGHT NEAR THE HI PRESSURE PORT.
MIKE
yes I did
yeah, got into the 1.3 so ft's 12 lb tire pressure and changed shocks to double adjustable, went 3.96 330 ft 6.15 1/8 mile 1.39 60 ft.
had a tranny leak-front pump gasket...got one pass only.
heading to track this weekend for index race.
mike
mike
gasket
No. the gasket is the front pump gasket, my fault i think . I changed bell housings to an aftermarket and I think I tore it but didnt know it until it leaked, should have leaked right away but didnt.
the index is a 6.20 index 1/8 mile
Mike
Mike
